Introduction: How to Make an Epoxy Resin Tabletop
In this project, I’ll be sharing my experience with creating a neat little epoxy resin table for my 2-year-old daughter.
The back story is she loves to follow me from room-to-room, and I love having her around me. Being a content creator, I am always on the computer trying to get work done. As long as I'm in her sight, that’s enough. I made her a desk awhile back, but that was too bulky to lug around. This is why this table came about. For our purpose, it’s a kid's table. For others this would make a perfect nightstand or end table. The same concept can be applied to any surface. The resin I’m using is from countertop epoxy. There is certainly many brands out there this is the one I have experience with. I went with epoxy because it’s durable and easy to maintain. The more layers you have the more you can wet sand it to remove scratches.
Projects Details:
- Countertop epoxy: http://bit.ly/2nrr vVk to get 10-percent off. Used promo code “diycreators”
- Colors used: White (prime coat), Aged Brown, Turquoise, Light Brown, Silver, Black http://bit.ly/2MlpHLM
- 16in hairpin legs https://amzn.to/2CWiVYA
(1in)X(24in) pine edge glued panel round board Click here
Project's cost: $105
Estimated time: 3 days (approx 5 hours spent)
For additional details (tools used etc,) see the post on my site diycreators.com
If you like this post, make sure check me out on the links below:
Subscribe to my YouTube Channel: Click here
Follow me on Instagram: Click Here
Step 1: Getting Started
This was a two-part process. The first pour was the base (I went with white). After pouring the resin on the workpiece, I used a brush to evenly spread it. It also helps if you’re on a leveled surface. Now you’ll need to remove the bubbles. I tried a heat gun and I was not a fan, I like the torch better. This part is quite simple; start from one end then work your way to the other. Keep the torch moving, once you’re done it should look like glass. Now, begin your second pour, adding all the colors you will want to see in the mix. Once you’ve mixed the second container of epoxy, you will transfer it to a new container (I used plastic cups). Then is when you’re going to add your individual colors.
Step 2: Mixing the Epoxy
The epoxy used in the projects is a 1-to-1 mix. One part hardener; one part resin. If you check on the countertop epoxy website, you will find a chart to help you with square footage coverage. Twenty-four ounces of resin was just the right amount for this 24-inch table.
Here is the mixing process I used:
- 12oz. Hardener part B +12oz.Resin Part A
- Pour the hardener into a mixing cup first follow by the resin
- Mix this for 5 minutes
- Pour into a new container and add your base color and mix for 4 more minutes.
- You’re now ready
You will repeat the same process for each pour. For the final coat, I just used the resin with no color.
Step 3: The First Pour
This was a two-part process. The first pour was the base (I went with white). After pouring the resin on the workpiece, I used a brush to evenly spread it. It also helps if you’re on a leveled surface. Now you’ll need to remove the bubbles. I tried a heat gun and I was not a fan; I like the torch better. This part is quite simple, start from one end then work your way to the other. Keep the torch moving -- once you’re done it should look like glass. Now, begin your second pour, adding all the colors you will want to see in the mix. Once you’ve mixed the second container of epoxy, you will transfer it to a new container (I used plastic cups). This is when you’re going to add your individual colors.
Step 4: The Second Pour
For the second pour, I used a dirty pour technique. I used a total of five colors, but you can pick all the colors you would want to see in the end result. I then took a piece of 4-inch pipe and placed it on the white base. Make sure you have everything prepped and ready-to-go, it’s best if you do all of this within 30 to 45 minutes of pouring the base.
Now, pour all the colors into the PVC pipe. Do not mix it!
Next, slightly spin and lift the PCV tube and push it in the desired path. It would help if you draw out a pattern path first, rather than to try and figure it out while in the motion. I kept it simple; I pushed the resin in one direction then back. You can try anything you like, swirling the pipe, zigzag, or whatever comes to mind. You can even tilt the workpiece to create movement in the design. Once you get the pattern you like, take the torch and remove the bubbles. Then, let this sit for 24 hours.
Step 5: Day Two
Inspect your work piece. If that looks good, then you are set. As I said in the video, I ran into some mishaps, so I had to address that before moving on. Had my process worked out in my favor I would have been done. Adding a layer of clear coat would only help, and I would still recommend it -- especially if you love the design. An additional clear coat adds protection. I’d recommend lightly sanding it with the following: 120-grit, 220-grit and 400-grit, prior to pouring the clear coat.
Remove the sand dust with a wet rag. Make sure the surface is dry. Mix up enough resin to cover the top and then pour it on the work surface. Take a brush and spread it, followed by the torch. Let this sit for 24 hours.
Step 6: Day Three
Clean up the hardened drips on the bottom.
Step 7: Add Legs
For this project, I used hairpin legs to keep things simple. Feel free to go in any direction.
Step 8: Final
Here is the finished product. Lia is enjoying her new table!
I hope you enjoyed this post if you did I would love to hear what you think about it. Let me know if you have any questions. Thanks for stopping by, and check out my links below to stay up today and see what’s next to come.
