Introduction: HOW TO MAKE a MINI TATTOO GUN / TATTOO MACHINE | TUTORIAL
https://www.youtube.com/watch?v=o2Mjib2FgwI&feature=youtu.be
Step 1: To Do a MINI TATTOO GUN You Need!!!
How to make a tattoo machine with your own hands?
You need: gel-ink pen with the refill, guitar string, motor from a player with the plastic roller, wires, power supply module.
Take:
- a gel-ink pen and remove the refill from it.
- Squeeze a small ball from the refill or squander it on an emery brick.
- Take a guitar string and try to stick it into the formed hole.
- If the string doesn't fit, squander a circled part of the refill with the emery paper.
- Shorten the body of the pen nearly two times.
Step 2: Fix the Motor With the Help of the Metal Angle and Scotch Tape.
Step 3: Take a String and Mark, Approximately, a Needed Length. the String Length Must Correspond the Pen Refill Length.
Take:
- Neatly edge one end of the string at the grindstone – that would be a needle.
- Bend the second end of the string, which will be linked to the motor at the 900 angle!!
- Make a hole in the motor roller with the help of the heated (string) needle.
- Depth of the complete outcome of the needle must be 1,5-2 mm.
