Introduction: HPD F1 - Evo
This is a radio controlled 1:10 scale F1 car intended for competition racing.
Before you start I want to encourage you to be quick to report any problems you encounter. The quicker we correct the problems the easier it will be for the next person.
Any thoughts, question, problems, suggestions may be posted as a comment below or, preferably, more personally on Discord: https://discord.gg/haqPpKY
STL files
Chassis: https://cults3d.com/en/3d-model/game/hpd-f1-version-3
Rear axle: https://cults3d.com/en/3d-model/game/hpd-f1-carbon-rear-axle
Front wing: https://cults3d.com/en/3d-model/game/f1-front-wing
Rear wing: https://cults3d.com/en/3d-model/game/crash-resistant-rear-wing-to-f1-cars
Spacer clips: https://cults3d.com/en/3d-model/game/spacer-clips-for-f1
Body: https://cults3d.com/en/3d-model/game/body-fro-hpd-f1-evo
Bill of materials
Following list is for your convenience. If you prefer Torx screws or Tamiya front springs you may try. Feel free to replace to anything compatible. You can probably even use some Imperial measurement screws if you so wish.
Suggestion: Buy more to have spares. The springs are especially easy to lose.
Screws# Description Part no 8 M3x12 counter sunk ISO 10642 5 M3x10 counter sunk ISO 10642 4 M3x8 counter sunk ISO 10642 0 M3x6 counter sunk ISO 10642 4 M3x14 button head ISO 7380 5 M3x12 button head ISO 7380 4 M3x10 button head ISO 7380 4 M3x8 button head ISO 7380 2 M3x6 button head ISO 7380 3 M3x18 socket head ISO 4762 2 M4x25 Hexagon head ISO 4017 1 M3 nut ISO 4032 2 M4 nylock nut ISO 7040 2 M4x20 Counter sunk ISO 10642Generic parts
# Description Part no 8 5.8mm ball end 9655000173-0 (Hobbyking.com) 4 5.8mm ball end socket 9655000171-0 (Hobbyking.com) 1 48.5mm Shock absorber 9655000144-0 (Hobbyking.com) 2 Ø3mm x 36mm Steel pin 2 6x9mm X-ray side spring 373585 (x-ray) 2 3.6x6mm X-ray front spring 372180 (x-ray) 2 8x12x3.5mm ball bearing 4 6x10x3mm ball bearing 1 Pinion (25T 48 pitch) #413 (kimbroughracingproducts.com) 1 Spur gear (69T 48 pitch) #160 (kimbroughracingproducts.com) 1 Servo saver #114 (kimbroughracingproducts.com) 2 33mm turnbuckle 3 Body clipsElectronics
# Description 1 Low profile servo 1 Radio receiver 1 Electronic speed control 1 21.5T motor
Step 1: Chassis
3D printed parts:
File Support main_chassis.stl Yes front_chassis.stl No front_damper_mount.stl No
Hardware needed:
# Dimension Description ISO 2 M3x12 countersunk screw ISO 10642 2 M3x10 button head screw ISO 7380 1 5.8mm 5.8mm ball end n/a
Ball end is available here: https://hobbyking.com/
Assembly
- Insert front chassis into rear chassis. Use the M3x10 screw to hold them together.
- Mount the front damper mount with the countersunk screws.
- Add the ball end on the rear of the chassis
See video for more info.
Step 2: Front Upper Arms
3D printed parts:
# File Support Infill 1 upper_arms.stl Yes 100% 2 camber_socket.stl No 2 camber_screw_block.stl No
Hardware needed:
# Dimension Description ISO 2 M3x18mm Socket head screw ISO 4762 2 M3x6mm Button head screw ISO 7380
From previous steps
Assembly
See video, steps:
- Ensure that the 3mm pin is freely moving, with minimum play, in all holes
- Place the camber screw (M3x18mm socket head)
- Lock the camber screw with the camber_screw_block, secure with the M3x6mm screw.
- Use the camber screw to attach the camber_socket. Carefully, do not screw too far.
Step 3: Front Arms Assembly
3D printed parts:
# File Support Infill 1 lower_arm_left.stl Yes 100% 1 lower_arm_right.stl Yes 100%
Hardware needed:
# Dimension Description ISO 4 M3x12mm Countersunk screw ISO 4762
From previous steps
2 Ø3mm x 36mm Steel pin 1 Upper arms
Assembly
See video, steps:
- Mount lower arms. NOTICE ANGLE! King pin should lean backwards.
- Mount upper arms
- Ensure that the king pin is moving freely
Step 4: Motor Pod
3D printed parts:
# File Support Infill Material 1 pod_front.stl no 100% 1 pod_left.stl no 100% 1 pod_right.stl no 100% Nylon, PETG or similar 1 pod_rear.stl no 100%
The motor is mounted on "pod_right" and becomes 70 degrees Celsius. Therefore you will need a heat resistant material in this component.
Hardware needed:
# Dimension Description ISO 5 M3x10mm Countersunk screw ISO 4762 2 M3x12mm Countersunk screw ISO 4762 1 M3x12mm Button head screw ISO 7380 1 M3 Nut ISO 4032
Assembly
See video, steps:
- Place a M3x10 screw in the ball clamp, do not tighten yet.
- Place the M3 nut into the socket on "pod_right".
- Use the M3x12 button head screw to connect the upper part of pod_front and pod_right.
- Use a M3x12 counter sunk screw to connect the bottom part.
- Use a M3x12 counter sunk screw to connect the bottom part of pod_front and pod_left.
- Use the 4 remaining M3x10 counter sunk screws to attach the pod rear.
Step 5: Mount Motor Pod
3D printed parts:
# File Support Infill 2 motor_pod_stab.stl no 100%
Hardware needed:
# Dimension Description Part no 4 M3x14mm Button head screw (ISO 7380) 1 48.5mm Hobbyking shock absorber 9655000144-0 2 5.8x6mm Hobbyking Ball end 9655000173-0
From previous steps
1 Chassis 1 Motor pod
Assembly
See video, steps:
- Place the m3x14 Button head screws into the motor_pod_stabs.
- Place the motor pod on the chassis protruding ball end.
- Screw the motor pod stabs on place.
- Add the shock absorber.
Step 6: Side Suspension
3D printed parts:
# File Support Infill 1 side_suspension_mount.stl no 100% 1 spring_holder_xray.stl no -
Hardware needed:
# Dimension Description ISO Part No 2 M3x10mm Button head screw ISO 7380 2 M3x12mm Button head screw ISO 7380 2 6x9mm X-ray Side Spring 373585
From previous steps
1 Assembled Chassis
Assembly
See video, steps:
- Screw the M3x12 button head screw to the holes second furthest out.
- Screw the spring_holders on the screws
- Add side springs.
- Thread the side suspension on place.
- Secure it on place with the M3x10 screws.
Step 7: Rear Axle
Hardware needed:
# Dimension Description 2 8x12x3.5mm Ball bearing
From previous steps
1 Assembled Chassis
From other project
Carbon Rear axle : F1 Carbon axle
Assembly
See video, steps:
- Add a spacer washer on the diff side of the axle.
- Add one ball bearing.
- Insert the axle in the motor pod.
- Add the second ball bearing.
- Add the hex drive (with wheel in the video).
- Tighten the screws to secure.
- Do not forget about the wheel nuts.
Step 8: Motor
3D printed parts:
# File Support Infill Material 1 motor_clamp.stl no 100% 100% PETG/Nylon
Hardware needed:
# Dimension Description 1 21.5T Brushless motor 2 M3x12mm Button head screw ISO 7380
From previous steps
1 Assembled Chassis
Assembly
See video, steps:
- Insert screws into the holes on the motor clamp.
- Insert the motor from the bottom.
- Secure the motor with the motor clamp
- Add pinion.
- Adjust gear play
Step 9: Steering Hubs
3D printed parts:
File Support steering_hub_left.stl no steering_hub_right.stl no
Hardware needed:
# Dimension Description ISO 2 M3x8 screw ISO 7380 2 M4x25 Hexagon head screw ISO 4017 2 5.8mm 5.8mm ball end n/a 2 Ø3mm x 36mm Steel pin
NOTE: 1. the M4x25 is replaceable with M4x30. Should be hexagon head though. 2. The ball end can be any ball end of your choice.
Assembly
NOTE: the steering hubs are asymmetrical. There is a right and left and up and down.
The "down" side of the steering hub has a small pyramid around the hole for the steel pin (the King Pin) while the upper side is flat.
- Ensure that the steel king pin is going trough the steering hub. Leave it in.
- Screw in the M3 screw into the steering hub until it holds the steel pin. Then unscrew one turn.
- Remove the king pin.
- Add the M4 screw.
- Add the ball end on the "upper side" of the arm.
Step 10: Front Wheels
3D printed parts:
File Support wheel_bearing_shim.stl no
Hardware needed:
# Dimension Description ISO 4 6x10x3mm Ball bearing
Assembly
As we are using a 6mm axle instead of the customary 5mm we have to use a different ball bearing to what you are used to. This also means that we need to compensate for the thinner ball bearing by inserting a shim on the inside of it.
Steps (in video):
- Insert shim.
- Add ball bearing.
- Repeat until done.
Step 11: Front Suspension
Hardware needed:
# Dimension Description 2 Front springs
From previous steps
1 Assembled Chassis. 2 Steering hubs. 2 Steel pins.
Assembly
See video, steps:
- Place steering hub (Note difference between left and right)
- Slide steel pin from the bottom until it is flush with the top of the steering hub.
- Hold the spring above the pin.
- Slide the pin through until it is cresting the upper arm.
Step 12: Steering Linkage (and Servo)
Hardware needed:
# Dimension Description 1 Low profile Servo 1 Servo saver 2 32-38mm turnbuckles 4 ball ends 4 ball end sockets 4 M3x8 Counter sunk screws
From previous steps
1 Assembled chassis
Assembly
See video, steps:
- TBW.
Step 13: Front Wheels
Hardware needed:
# Dimension Description 2 M4 M4 nuts
From previous steps
2 Front wheels with bearings
Assembly
See video, steps:
- Attach wheels....
Step 14: Rear Wing
Hardware needed:
# Dimension Description 2 M3x8 Button head screw
From previous steps
1 The chassis
From other project
Rear wing: Crash resistant rear wing to F1 cars
Assembly
See video, steps:
- Attach wing....
Step 15: Front Wing
3D printed parts:
# Name 1 body_mount_front.stl
Hardware needed:
# Dimension Description 2 M4x20 Counter sunk screw
From previous steps
1 Chassis
Assembly
See video, steps:
- Attach the front wing..
Step 16: Mounting Electronics
This is mostly a personal choice. Look at picture to get inspiration.
Step 17: Secure Battery and Mount Body.
3D printed parts:
# Name 1 battery_lock.stl
Hardware needed:
# Dimension Description 3 Body clips
From previous steps
1 Chassis
From other projects
