Introduction: Project 2: Introduction to 3D Print
This document is about the introduction to 3D print with Creality Ender 3 Pro 3D Printer in assignment 2.
In the first part of the document, the first trial of 3D print is described.
In the second part, the first production of a stackable snack bowl is described.
Step 1: A First Trial 3D Prints
First, when I got a printer, I tried to 3D print test objects.
As you can see in the left figure, "cat-3.5H.gcode" was successfully printed out. It took around 5 hours.
The right figure is failed test object of "dog-2.5H.gcode". Because the 3D print material line was broken on the way to print, I stopped the 3D print.
For the troubleshooting, I changed a different material and restart the 3D print again.
Step 2: The Production of Stackable Snack Bowl
Next, I created a stackable snack bowl using the example code provided by Jennifer.
Left figure, I drew a line on the Rhino part. The line will be the shape of the bowl.
The not closed line is input as a curve to "RevSrf", rotates, and creates a shape of a bowl.
In the python code, it is the same as the example code of Creating a Stack of Transformed Objects.
The output is geometry shape. The output shape was extruded along a vector in "Extr" and performed a solid union in "SUnion" in order to output STL file*.
*To output STL file, I selected the 3D object in Rhino and select the Export from File on the menu bar.
Step 3: Check the Output and Stackable
From the program code and Grasshopper process, the output of the model object is like the left figure.
Next, I checked if stacking this bowl works or not.
I changed parameters like the right figure, duplicated the bowl, and from the Rhino, I performed the "BooleanUnion."
From the BooleanUnion, when I stacked the stacked object was stacked without changing the shape.
Therefore, it means that the bowl shape is able to stack.
Step 4: STL File and Slice in 3D Cura
The output STL file is shown left figure.
When I import the STL file in slicing software 3D Cura, I found the object size was pretty small to use.
Therefore, I used the function of size change, I expanded the object to 350% from the original size.
If I sliced one bowl can be printed out in 2 hours and 47 minutes.
The original small size bowl can be printed out in 9 minutes.
I need 3 of the bowl to stack. Therefore, I duplicated, sliced again and checked the time.
The duration of the printing time showed 8 hours and 34 minutes.
Step 5: 3D Print Process
Step 6: Done!
The actual duration of 3D print was 8 hours and 7 minutes shown in the display on the 3D printer.
At this time, for easy washing, I did not put any ornament on the bowls.
These bowls work very well as a snack bowl.
When I stacked, these were stacked very well!!
