Introduction: HX1838 VS1838 NEC Infrared IR Remote Control Sensor Module for Arduino
About: electronics projects involve creating and experimenting with electronic devices and circuits for personal enjoyment and learning. These projects range from simple circuits like flashing LEDs to more complex bu…
It is really easy to control an Arduino using an infrared remote. There is one particular remote that is available from multiple sources and is really quite cheap, they look and operate in a very similar way.
NEOMART Raspberry Pi HX1838 Infrared Remote Control Ir Receiver Module DIY Kit.
Kootek Raspberry Pi Infrared Remote Control Ir Receiver Module DIY Kit.
KIT,IR REMOTE,IR RECIVER,ARDUI,COMPATIBLE
The problem is that documentation seems to be scarce for these particular remotes. Here is how I figured out how to use them.
Step 1: Assemble Circuit
You will need one Arduino for this. I used a UNO, but just about any Arduino should work. First wire up the infrared receiver that came with your kit. There are 3 wires, PWR, GND, and SIG, I used port 11 for SIG. Note! some readers have reported that their sensor has different wiring, double check it yourself.
Step 2: Download IR Library
In order to reverse engineer the remote and obtain the codes for each button we are going to need to download and install the following library.
https://github.com/shirriff/Arduino-IRremote
Extract the file in your libraries directory. e.g. ( C:\electronics\arduino-1.0.5\libraries )
note: I had to rename the library because the name was too long, I just renamed it to IR.
Step 3: Add Library to Sketch
With the IR folder ( or whatever you named it) now in your libraries directory, we can import it into a new sketch.
Start a new sketch and the Click
        Sketch->Import Library->IR.
Step 4: Paste Code and Compile
Paste the following code into the new sketch. Then verify it compiles.
#include <IRemote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
void loop()
  if (irrecv.decode(&results))
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
Step 5: Open the Serial Monitor
Connect the Arduino to your computer using the usb port, then upload the sketch. Open up the Serial Monitor, get the remote and press the buttons. Some hex codes should appear on the Serial Monitor.
Step 6: Record Button Codes
Here are the codes that I got for the white remote. FFFFFF is a repeat command, you'll get a stream of them if you hold down a button.
PWR      FF629D
CH       FFE21D
|<<        FF22DD
>|           FFC23D
>>|      FF02FD
-            FFE01F
Plus      FFA857
EQ        FF906F
0            FF6897
100       FF9867
200       FFB04F
1            FF30CF
2            FF18E7
3            FF7A85
4            FF10EF
5            FF38C7
6            FF5AA5
7            FF42BD
8            FF48B5
9            FF52AD
and here are the codes I got from the black remote.
PWR                   FD00FF
VOL                              FD807F
FUNC/STOP                  FD40BF
|<<                                  FD20DF
>|                                    FDA05F
>>|                                  FD609F
DOWN                            FD10EF
VOL                                FD906F
UP                                  FD50AF
0                                     FD30CF
EQ                                  FDB04F
ST/REPT                       FD708F
1                                     FD08F7
2                                     FD8877
3                                     FD48B7
4                                     FD28D7
5                                     FDA857
6                                     FD6897
7                                     FD18E7
8                                     FD9867
9                                     FD58A7
Step 7: Works on Any Remote!
Now go grab a bunch or remotes from around the house, and give those a try! I got a direct-tv remote and the smartphone pod/remote for a Helo TC remote controlled helicopter. This circuit showed the code for both of these remotes.
