Introduction: Hack an Old-fashioned Charger Into Latest Removable Plug & USB Charger
TURN AN OLD FASHIONED PIN CHARGER INTO PORTABLE REMOVABLE PLUG AND USB CHARGER UNDER 1 DOLLAR,AND SHOW OFF TO YOUR TILL THEY FEEL JEALOUS TO YOU.......
Step 1:
Open your charger and take out the circuit board.You can see the two wire red for positive and white for negative and there is two metal tip for ac voltage.
Step 2:
Fix USB Extension Cable in your plastic case.There is four wire 1-red ,2-white ,3-black and 4-green.Cutout the white and green wire Red wire is for positive and black for negative.Fix first 9v battery clip and plug into the wire.Now fix second 9v battery clip into your plastic case.
Step 3:
Join USB red wire to charger red wire and USB black wire to charger white wire.Now for AC Voltage solder the battery clip black wire to negative wire of charger and red wire to positive terminal of charger.IMPORTANT NOTES- Today there is different types of charger people have so for AC Voltage there is red and black wire so you can join that wire with battery clip and cover it with electric tape.Install all the components..................
IF YOU DON`T WANT TO USE BATTERY CLIP SO DON`T USE.IN THE PLACE OF BATTERY CLIP YOU CAN USE SINGLE PLUG HOLDER AND FOR SECOND BATTERY CLIP YOU CAN USE PLUG.I AM USING THIS CHARGER WITH BATTERY CLIP FROM 3 MONTHS AGO
IF YOU LIKE THIS POST THEN PLEASE GIVE YOUR IMPORTANT FEEDBACK
