Introduction: Hack124x768's Pump Action Rifle (Step by Step)
About: I like to play my DS, make knex guns, play PS2, hang out w/ friends, watch TV, jump on the trampoline, and surf the web.
Hi. I made Hack124x768's pump action rifle and liked it a lot, but a lot of people (including me), couldn't figure out this gun, so I made this instructable which includes everything. Hope this helps. Here is the original instructable. Please comment and don't forget to rate!
Step 1: Piece List
Connectors
Red-21
White-24
Yellow-30
Gray-60
Light gray-3
Green-40
Orange-32
Rods:
Red-3
Tan-1
Green-98
White-63
Blue-20
Yellow-14
Gray-5
Other:
Blue Hinge Half-1
Black Hinge Half-1
Blue spacers-7
Tan clips-7
Small rubberband-1
Normal rubberband-1
Large rubberband-1
*Numbers subject to counting errors
Step 2: Hopper
This is the hopper.
1. Make this
2. And this
3. 2 of these
4. Connect
5. Connect
6. Add these
Step 3: Trigger
Make the trigger.
1. Make this
2. 2 of these
3. 2 of these
4. Add blue rods and orange connectors on ONE of them
5. Add a piece from picture 2
6. Insert piece from picture 1
7. Other piece from picture 2
8. Other piece from picture 3
Step 4: Pump
This is the pump.
1. Make 8
2. Put all on red rods
3. Slide one down and add extras
4. Add a white connector and gray connectors
5. Make this
6. Add a gray rod and gray connectors
7. Slide on piece from picture 5
8. Add gray rods
Step 5: Firing Pins, Rubberbands, Connecting, and Frame
Refer to title
1. Add pump
2. Make this
3. Insert and add rubberband
4. Add tan rod and gray connector
5. Add orange connector and yellow rod
6. Add a rubberband (I doubled mine)
7. Make and add the front frame
8. Make this
9. Add to trigger
10. Add front frame and new pieces
11. Connect...
12. Add the other pieces
13. Add rubberband to pump
Step 6: Loading and Firing
How to load and fire:
Pull back pump. Block will fall and stop firing pin. Open the "door" on the hopper and load 10 blue rods. Pull trigger. Pull back pump. Block will fall and stop firing pin. Pull trigger. Pull back pump. Block will fall and stop firing pin. Pull trigger. Pull back pump. Block will fall and stop firing pin. Pull trigger. Pull back pump. Block will fall and stop firing pin. Pull trigger. Pull back pump. Block will fall and stop firing pin. Pull trigger. Pull back pump. Block will fall and stop firing pin. Pull trigger. Pull back pump. Block will fall and stop firing pin. Pull trigger. Pull back pump. Block will fall and stop firing pin. Pull trigger. Pull back pump. Block will fall and stop firing pin. Pull trigger. (Aren't I annoying?)
Have fun!!!
