Introduction: Hacking Alexa (Echo Dot Gen. 3) a Little Bit to Make It Able to Switch Between Internal and External Speaker
About: Hey I'm Rene and i love to work on projects that contain electronics, 3D Prints and Hot Glue. I love building Circuits using Arduino and ESP8266 or ESP32. I'm currently studying mechanical engineering.
I was looking for an easy way to make alexa able to switch between internal and external speaker utilizing a ESP82366 Wemos D1 Mini and Tasmota
Wemos D1 Mini
Alexa Echo Dot 3. Gen
Enemal Wire
2x Resistors 4.7k
Shrinkwrap
Step 1: Finding a Way to Enter
I wanted to use the Echo as my spotify interface to my hifi amplifier, since it has an 3.5mm audio jack and it is quiet cheap (i paid 17.99€). The only problem is you either have to keep your hifi amplifier on all the time or unplug the 3.5mm Cable each time you turn off the amplifier. Otherwise you won't be able to hear Alexa when your Amplifier is switched off.
Since I'm switiching off my amplifier with a sonoff smart plug and manually unplugging the audio cable each time was not an option for me i needed to find a different solution.
Time to void the warranty. Opening up the echo you see the first pcb thats hosts both, the power and the audio jack. I was looking for some circuitry that generates a logic singal if audio jack i plugged in or not, as described in linked paper from TI.
Unfortunately i didn't find out which chip exactly handles this task. But i found out, that the signal on testpoint TM56 is the signal i was looking for.
As you can see in the picuters, Logic is the following:
Nothing plugged in --> ~1.56 V (High) Signal.
3.5mm Audio Jack plugged in --> 0V (Low) Signal.
Step 2: Intercepting the Signal
Now i only needed to emulate this signal somehow, to fool alexa. Using Tasmota (Open Source home automation software, to make your microcontrollers smart) flashed on a ESP8266 (Wemos D1 Mini, it perfectly fits) would do the job. Using a simplet 50/50 Voltage devider to bring the 3.3V outputs to an acceptable level i wired up the WEMOS the following.
Step 3: Configuring Tasmota
My Tasmota Pin Configuration looks like the following:
Pin D4 as inverted Relay, so i switches low when i turn it "on". D2 as LED Output for Debugging. In the Alexa app now i grouped the hifi amplifier and the tasmota switch, so both are switched with one command.
Wifi reception is good even though its mounted underneath a big aluminium die cast housing.
