Introduction: Hair Retouch
A guide on how to give someone or yourself an easy hair dye touch up. In order to do this, you must know about color formulation.
  • Hair Dye
  • Creme Developer (20 Vol)
  • Brush Applicator
  • Measurement cup
  • Bowl
  • Hair Clips
  • Cape
  • Gloves
Step 1: Before Picture
Take a before picture, when building your brand or starting off as a new cosmetologist this is how you start building your portfolio.
Step 2: Drape & Prep
Drape your client with a cape and part his/her hair into 4 sections. Put on protective gloves, since you will be working with chemicals.
Step 3: Formula
Mix your formula. This is where your knowledge on color formulation comes in handy. All color brands are different so make sure you read the color to developer ratio. For the brand that I am using, I added two ounces of creme developer with 2 ounces of hair dye. Once I have everything in the bowl, I mix until I get a creamy consistency.
Step 4: Application
Start by coloring the roots in all four sections and the hairline as well. Once you are done with the roots you may begin with the rest of the hair starting out on either one of the front sections, Move to each section until all of the hair is saturated. Once you are done saturating the hair, give the hair time to process by following the instructions of the hair dye you are using. Processing time is usually between 30-45 mins.
Step 5: Wash & Style
Once the hair is done processing, wash the clients hair. Once the water is clear of color, blow dry your clients hair and style if needed. That is the basic way of applying and retouching some one's hair color.
