Introduction: Hairstyles to Wear to Bed!
Every morning when I wake up, my hair is super messy and painful to brush out, but when you were these to bed, there are many benifits including, going to bed in style, and super easy-to-brush-out hair!
Step 1: Doble Up!
This Hairstyle includes two braids and they lie flat so they do not annoy you when you are sleeping!
- Brush out your hair untill it is super soft.
- Split hair into two equaly mached sections of hair and put each of them over their respective sholders.
- Pick one section and use two fingers to divide into three sections. Try to make them about equal.
- Take the one closest to your face and place it between the other, now it should be in the middle.
- Now take the farthest one from your face and place that in the middle.
- Continue doing this untill you reach just before the end of you hair and secure it with a hairtie.
- Now do steps 3-6 on the other side, then you have a pair of perfact braids!
Step 2: Or Just One
For This you can do a single braid, these are supercool because they stay out of your way all night, but be relitivly loose when brading these beacause they is they are braided too tight then they will annoy you all night!
- Start with a low ponytail on the base of your neck.
- Using two fingers divide it into two sections.
- Take one side and place it in the between the other two so it is not the middle.
- Take the pice from the other side and put that one in the middle.
- Continue doing this untill you reach the bottom of your hair, then put another elastic on it.
Step 3: Beachy Bun!
This is one that I like to use because it keeps the hair off my neack, and that is super important when you live in a place that gets hot durring the summer!
- Pull your hair up into a high ponytail position and wrap the elastic around it once.
- Wrap the elasic again but this time only pull the hair halfway through it.
- Tighten once more if needed, then you have a perfect bun!
Step 4: Done!
I wish you sweet dreams to go along with your sweet hair!
