Introduction: Half Hitch Knot
The Half Hitch is basically an overhand knot tied around an object. Typically the half-hitch is used as the start of more complex knots as it is not secure on its own.
I find it is best to practice on a table leg.
In the description you will find the terms ‘load side’ and ‘working end’. For those of you that might be learning how to tie a knot for the first time, the ‘load side’ of a rope is the part of the rope that is not active in knot tying and the ‘working end’ is the part of the rope that does all the work.
Step 1:
Holding the rope in your left hand take the working end (pointing away) of the rope and make a loose loop to the right around your table leg. Overlapping the load side of the rope, the working end should be pointing to the left.
Step 2:
Twist the working end under the load side and up through the loop
Step 3:
Pull on the working end and load side of the rope to tighten the Half Hitch Knot.
Brought to you by areyoureadysurvivalkits.com. Your first choice in online Camping equipment & Survival Kits for pleasure, office and your family including your pets. “Be Ready for Tomorrow, Today”
