Introduction: Halloween Crochet Ghost Hand Puppet
Crochet Hand Puppets are a favorite among the kids. They just look super cute. Crochet Hand Puppets are a versatile project to make. You can make them for hands or you can even make cute small puppets for fingers. Either way they are always fun to make. Crocheted Hand Puppets make great gifts and are a great option for Craft Fairs.
With Halloween around the corner , this would be the best best time to make some Ghost themed crochet projects. Today am sharing the pattern for Halloween Crochet Ghost Hand Puppet. I made this as a part of the 2024 Halloween Crochet Along with Marie at Underground Crafter.
The pattern is super easy which is made with only single crochets. The size of the hand puppet is easily customizable. You make as big as you want or as small as you wish.
Visit https://rajiscrafthobby.blogspot.com/2024/09/halloween-crochet-ghost-hand-puppet.html
8 / 5 inches- Customizable to any size
8 Ply Cotton Yarn - 1 Skein
Black Yarn or Puppet Eyes
5 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot- Leave a long Tail end while making the Slip Knot.
Keep the Tail End Down and the Working Yarn on the Top.
**Wrap the Tail end on the hook , Yarn Over the Working Yarn and Pull Up a loop** - This will make 1 Stitch. With This method you will have a neat finish.
Repeat from ** to ** untill you have total 30 Stitches.
This measures around 5''.
Slip Stitch into the 1st Stitch
Before making the slip stitch, wrap it around your wrist and check the size.
If you find the size to be big or small, then you can increase or decrease the number of chain stitches.
Step 3:
Round 2:-
Chain 1(This is not counted as stitch. This is just to bring the yarn to the height).
1 Single Crochet in the same.
1 Single Crochet in each of the remaining stitches.
Once you reach the end, do not slip stitch.
We will be working in continuous rounds.
30 Stitches.
Step 4:
Round 3 to Round 12:-
1 Single Crochet in each stitch around.
Use a Stitch Marker to keep a count of the stitches.
Step 5:
Round 13:-
2 Single Crochets in the first stitch.
1 Single Crochet each in the remaining stitches untill the 15th Stitch.
2 Single Crochets in the 15 the Stitch.
1 Single Crochet each in the remaining stitches.
32 stitches.
- The increases will be made at the start and one more increase exactly on the opposite side of the first stitch.
- I started off with 30 stitches. So my increase will be at the 1st stitch and the next increase will be at the 15th stitch.
- Even if you are not keeping a track of the stitches, you can easily find the midpoint and make the increases.
- Lay the puppet flat and approximately find the midpoint , which would be exactly right on opposite side of the first stitch.
Step 6:
Round 14 & Round 15 :-
32 Stitches
Step 7:
Round 16:-
2 Single Crochet in the first stitch.
1 Single Crochet in each of the next stitches untill you reach the midpoint on the opposite side of the first stitch.(16th Stitch)
2 Single Crochet in the mid point.(16th Stitch)
34 stitches
Step 8:
Round 17 & Round 18:-
34 Stitches.
Step 9:
Round 19:-
1 Single Crochet in each of the next stitches untill you reach the midpoint.
2 Single Crochet in the mid point.(17th Stitch)
Cut off the yarn at the end of this round.
36 stitches
Step 10:
Round 20:-
In this round we will make the gaps for the Thumb and Pinky finger.
Count back 5 Stitches from the point which you have cut off the yarn and mark it with a stitch marker.
Count the next 10 stitches(from the stitch where you have put the stitch marker) and mark it with a Stitch Marker.
This will be the Gap for the Thumb.
Do the same at the other side and mark the gap for the Pinky Finger.
(Lay the puppet flat and approximately find the midpoint , which would be exactly right across the first stitch.)
You will be skipping these stitches. The Thumb and Pinky space will be made after we finish the head of the puppet.
Again lay your puppet flat, join the yarn and make 1 single crochet on each of the stitches untill you reach the thumb gap.
Skip the 10 stitches made for the Thumb Gap. Directly insert your hook on the other side and continue with 1 Single Crochet in each of the remaining stitches.
Step 11:
Round 21 :-
Step 12:
Round 22:-
1 Single Crochet, 2 Single Crochet
Repeat*(1SC,2SC)
Step 13:
Round 23 to 27:-
1 Single Crochet in each stitch all around.
Step 14:
Round 28:-
1 Single Crochet each in the next two stitches
1 Single Crochet Decrease in the next stitch.
Repeat*(1SC*2, 1SC Decrease)
To make a Single Crochet Decrease:-
Insert hook and draw up a loop - 2 Loops on the hook
Insert your hook into the next stitch and Draw up a loop - 3 loops on the hook.
Yarn over and draw through all three loops on the hook.
Step 15:
Round 29 onwards:-
Keeping repeating Round 28 untill the gap is closed.
Step 16:
Thumb and Pinky Finger:-
Go back to the stitches you have left for the Thumb and Pinky finger and Join the yarn.
4 Rounds of 1 Single Crochet in each stitch around.
Do Not Make a Slip Stitch -Work in Continuous rounds.
Last round, make 1 Single Crochet decrease in each stitches around or untill the gap is closed.
Step 17:
Eyes and Mouth:-
Use Black color yarn and sew the Eyes and Mouth or You can Clip On Amigurumi Puppet Eyes
