Introduction: Halloween Faux Flower Cloche
About: Artist...Photographer...Digital Content Creator...Creative...Florist...DIYer...Crafter...Maker. Founder of 'Mia Bella Passions' Blog. Circa 2012.
A faux flower cloche is such a simple adornment to create for your home.
The rich colours of the faux flowers are stunning.
If you choose colours similar to mine, it will carry this decor piece from Autumn (Fall) to Halloween, and then onto Thanksgiving.
To make a Halloween Faux Flower Cloche, you will need:
A selection of faux flowers, leaves, and berries.
A block of dried florist foam. (The size you need depends on the size of the cloche.)
Some mini velvet pumpkins and spiders.
Artificial autumn-toned maple leaves.
A clear glass cloche.
Step 1: To Create:
Cut the florist foam to size.
Place leaves around the block of foam to disguise it.
Step 2:
In the middle place a spray of berries and flowers that will be the height of the cloche.
Continue placing the flowers into the foam, leaving a space for three mini velvet pumpkins.
Step 3:
When you're happy with your floral arrangement, push a wire (I used the offcut pieces from the flowers) into the base of the pumpkins and place them into the foam.
Step 4:
Carefully slide the cloche over the arrangement.
Use a skewer to correct the placement of the petals and leaves.
Arrange the maple leaves on the table where your arrangement will sit.
Place the cloche and floral arrangement on top of the leaves.
Notes:
To enhance the ambience, you can add battery-operated mini fairy lights around the display or inside the cloche. This will create a warm, inviting glow, perfect for setting the Halloween mood!
Select a coordinated colour palette that invokes the spirit of Halloween. Create a cohesive and harmonious look by considering dark, rich blacks, vibrant oranges and yellows, burgundy, or mysterious purples. Reflect these autumnal colours in your table settings, from the tablecloth and napkins to the dishes and utensils, ensuring that every element feels connected. This coordinated styling approach will help unify your table display and make it visually stunning.
I decided not to put the spiders in the cloche and will have them on the table instead.
