Introduction: Halloween Graveyard Cake
This are instructions on how to make a graveyard cake for halloween complete with buried bodies for people to find
Step 1: Gather Your Ingredients
To do this you need lots of ingredients
First you need a large sponge cake
I made one using the recipe described on downsizer.net
My roasting tin which is 36cm by 26cm and about 5cm deep took a 9 egg version of the above sponge mix which I made chocolate flavour. I used a roasting tin as to achieve a sensible effect with the graves the cake needed to be quite deep. When filled the tin was half to 2/3rds full and it took 1hr to cook at 180/gas mark 4. As the article says this can vary from oven to oven so I would start checking it after about 45-50minutes. When cooked it should stop making noise and a stick/knife should come out relatively clean.
You also need
Icing
100-150g butter
100-150g Icing sugar
Green food colouring
Decorations
Digestive biscuits crushed to replicate gravel
Gravestone shaped biscuits
Pink Wafer biscuits
Jelly Babies
Jelly worms
Marshmallow ghosts
Red Jam
Candy sticks to replicate bones
Chocolate mice
mushroom sweets
Supercook writing icing (You get 4 colours in small tubes for about ÃÂÃÂÃÂÃÂÃÂÃÂÃÂã2 you could achieve the same effect with coloured icing and piping bags)
Cocktail sticks
Step 2: Digging the Graves
So I started with a sponge cake.
I used paper to vague plan where the gravestones and mausoleum were going to go
I used a small paring knife to cut the graves out. Being fairly careful with the sponge being removed as some of it would need to be put back.
Step 3: Burying Your People
The graves were then marked using cocktail sticks so once iced they could be located then filled with either jelly babies or strawberry jam and candy sticks.
Some of the removed cake was put back into the holes to allow them to be iced though one grave was left open.
Step 4: Planting the Grass
The icing was made with softened butter, green food colouring and icing sugar, they were mixed together to form a paste which tasted more of sugar than butter and dyed with green food colouring untill it would go no more green.
As I said in the ingredients list I used about 100-150gs of butter and icing sugar but this may vary depending on the size of your cake etc
Then the green icing was spread over the cake.
Step 5: Placing the Gravestones
Now I marked a path to a mausoleum I was building from pink wafer biscuits.
Then I started writing on the biscuits to be gravestones various things like RIP or In Loving Memory.
When the gravestones were placed I removed the cocktail stick and used a knife to make a small incision in which to place the biscuit before pressing down.
Step 6: Building the Mausoleum
The mausoleum was constructed from several pink wafer biscuits. This could be prised apart so the writing was done on thinner pieces then stuck onto the side using icing.
Step 7: Making the Path
Probably about a biscuits worth of crushed digestive biscuit was used to line the path.
It was pressed down into the green icing to ensure it remained stuck down.
Step 8: Final Decorations
I used cocktail sticks to place ghosts around the graveyard and just pressed the other sweets into the icing.
The cake was lovely and served about 25 people
10 Comments
13 years ago on Introduction
Did you used food colorant or something else ?? (if something else..please tell me what XD )
Reply 13 years ago on Introduction
The green was done using <a href='http://www.wilton.com/store/site/product.cfm?id=3e30b2d9-475a-bac0-5d5c3db846dfd354'>http://www.wilton.com/store/site/product.cfm?id=3e30b2d9-475a-bac0-5d5c3db846dfd354</a>
The writing was done using <a href='http://www.supercookonline.co.uk/index.php?act=viewProd&productId=93'>http://www.supercookonline.co.uk/index.php?act=viewProd&productId=93</a>
14 years ago on Introduction
Prior art! <snicker> Just kidding...
Looks like we had just about the same thought at the same time.
http://www.flickr.com/photos/23007508@N00/1779740861/
15 years ago on Introduction
How Creative, Can you make the pictures bigger?
Reply 15 years ago on Introduction
I have finally found the time to change the pictures, they should all be bigger now thanks
Most of them are. Nice work, btw. very neat.
Thanks!
Looks cute, but do you have any larger pictures of it? It is difficult to make out with such small photos!
There are bigger pictures on my picasa gallery here
picasa graveyard cake
this is amazing. I love creative cakes, and the buried bodies is a very clever touch.
