Introduction: Spare Key Spider Web
This is no ordinary Halloween themed door decoration. It contains a hiding spot for your spare door key!
I was inspired to create a hiding spot somewhere convenient to the lock and also hidden in a way that no one would expect. Can you guess where they key is? It's attached to the black & orange spider on the right hand side. Fun feature: the spider is attached to a retractable key ring, which means that you can extend it and unlock your door conveniently!
Step 1: Supplies
To create this Halloween decoration you'll need:
- Cardboard
- Black spray paint
- Pom poms
- Yarn
- Spiders
- Ribbon
- any extra decorations, like a garland
and also a
- Hot glue gun
- Scissors
- Tape
For the spare key hiding place you'll need a:
- Spare key
- Retractable key ring
- Small piece of pipe cleaner or a rubber band
Step 2: Trace & Cut Two Rings
Trace two circles on a large piece of cardboard. The circles should be different sizes, and create a large ring. I found some circular kitchen bowls and traced them. Another method is to take a piece of yarn. Attach a pen to the end & spin it around a center point.
Cut out the cardboard ring.
Step 3: Paint the Ring Black
Using the spray paint, cover both sides of the cardboard ring. Let it dry.
Step 4: Cut & Tape Yarn Strands
Cut out four pieces of yarn and tape them to the back of the ring. Cut another piece and tie a knot in the center, connecting all of the pieces of yarn together.
Step 5: Weave the Web
Cut out a long piece of the black yarn. To create the web, tie knots at each intersection of the pieces of yarn.
Cut a smaller piece of yarn and create the inner ring.
Step 6: Attach Your Spare Key
Now for the secret hiding place! Attach the key to the retractable key ring. Then, use the hot glue gun to attach the large spider.
Step 7: Secure the Spider
Then, glue it to the right hand side of the cardboard ring.
Step 8: Pom Pom It Up!
Cover the cardboard ring with pom poms! I chose to to stick with ones in a Halloween color palette (orange, green, purple, black).
Step 9: Add a Handle for Hanging
Cut a short piece of ribbon. Add hot glue to both ends and press it against the back side of the cardboard ring.
Step 10: Some Spiders & Garland Garnish
Glue a spider to the center of the web and also to the end of the dangling piece of yarn. Then, flip the wreath over and glue a garland around the edge.
Step 11: Try It Out!
Hang it on your front door and try it out!
