Introduction: Halloween Knapsack
When I was younger, I saw in Bealle store these halloween knapsack. I thought that might try to recreat the knapsack.
Step 1: Materials
Material:
- two orange fabric square
- sewing needles
- threads
- scissor
- shoestring
- safety pin
- paints is optional
Step 2: Pin End
First, you need to pin the two fabric square together at the ends so you can sew evenly.
Step 3: Stitch End
Then you sew the end first so it would be more easier to sew.
Step 4: Stitch Sides
Afterward, you sew one of the sides together and then the other. (Be sure to trim the sides for any
loose threads.)
Step 5: Inside Out
After you completely sew the two fabrics together, turn the knapsack inside out.
Step 6: Slips
Then cut a few slip in the fabric so the shoestring can go through.
Step 7: Tie String Together
After you slip the shoestring into the knapsack tie the shoestring together.
Step 8: Decorate
All you have to do is paint on the knapsack some halloween decoration and you can use it for trick or treating.
