Introduction: Halloween Project
Our Halloween Project is based in an horror theme grave. The candles have some fade effect, and the eyes of the skull are brighter as near as you are frome the grave.
List of the supplies needed:
- Led's (x6)
- Resistors (x6)
- Distance sensor
- Arduino uno
- Cables
- DM wood
- Candles (x4)
- Plastic Skull
- Welder
- Glue
Step 1: Make Holes in the Candles and the Skull
With a 6mm diameter make some holes through the candles and the eyes of the skull.
Step 2: Cut a DM Wood With the Grave .dwg File
For this step we would need the assist of a Laser cutting machine.
Step 3: Make Some Holes in the Upper Side of the Grave
Hole the upper side of the grave with the same diameter, the cables will go from the candles to the inside of it.
Step 4: Glue the Down and the Lateral Sides of the Grave Box
The upper side won't be glued, then we can modify or visualize the inside.
Step 5: Arduino Code and Protoboard Preparing
//ArduinoSkullProject 02/11/21
//by Roger Sauquet/ Gerard Cabezas/ Javier Fernandez
// Tutored by Carles Flotats
//Materias:
// - 4 LEDS
// - Arduino one
// - Electric cables
// - 3 Resistors
// - Protoboard
// - HCSR04 sensor
// - Perforated plate for welding
// - Skull (plastic)
// - 4 Candles
// - If you want to create a support you will need wood or cardboard pieces
// HOW TO ASSEMBLE IT?
// As we can see in the code we use specific inputs for each cable that will make the led work, so if we do not connect the cables correctly to the ports, the led will not perform the programmed function.
// The LEDs that we will use for eyes should be connected to ports 9 and 10. On the other hand, those of the candles will be connected to 11, 6 and 3.
// WARNING: You have to be careful and put the resistors correctly, otherwise the LEDs may stop working.
// Once the cables are correctly connected to the ports and the resistors are installed, it is time to place them in the desired place; load the program and start it.
// WHAT DOES THE PROGRAM DO ??
// This program made for Halloween, performs three simultaneous fades in the candles that work constantly, however the three fades are different (only two candles have it the same)
// In turn, the proximity sensor that is programmed to start detecting from 50 cm, when noticing something in its range, starts its cycle that and the closer we get to the tombstone, the brighter it will shine.
//CODE:
#include <HCSR04.h>
byte triggerPin = 5;
byte echoPin = A0;
int ojo1 = 9; // the PWM pin the LED is attached to, right eye
int ojo2 = 10; // the PWM pin the LED is attached to, left eye
int brightness = 0; // how bright the LED is when the eyes start
int brightness2 = 100; // how bright the LED is in two candles when start
int brightness3 = 120; // how bright the LED is in two candles when start
int brightness4 = 80; // how bright the LED is in two candles when start
int fadeAmount1 = 10;
int fadeAmount2 = 7;
int fadeAmount3 = 4;
int vela1 = 3; // the PWM pin the LED is attached to for two candles
int vela2 = 6; // the PWM pin the LED is attached to for two candles
int vela3 = 11; // the PWM pin the LED is attached to for two candles
void setup () { // the setup routine runs once when you press reset:
Serial.begin(9600); // initialize serial communication at 9600 bits per second:
HCSR04.begin(triggerPin, echoPin);
pinMode(9, OUTPUT); // initialize digital pin LED_BUILTIN as an output fir the right eye
pinMode(10, OUTPUT); // initialize digital pin LED_BUILTIN as an output for the leftt eye
pinMode(11, OUTPUT); // initialize digital pin LED_BUILTIN as an output for two candles
pinMode(6, OUTPUT); // initialize digital pin LED_BUILTIN as an output for two candles
pinMode(3, OUTPUT); // initialize digital pin LED_BUILTIN as an output for two candles
void loop () { // the loop routine runs over and over again forever:
analogWrite(vela1, brightness2); // set initial the brightness of the first pair of candles
analogWrite(vela2, brightness3); // set the initial brightness of the second pair of candles
analogWrite(vela3, brightness4); // set the initial brightness of the third pair of candles
brightness2 = brightness2 + fadeAmount1; // change the brightness of the first pair of candles for next time through the loop:
brightness3 = brightness3 - fadeAmount2; // change the brightness of the second pair of candles for next time through the loop:
brightness4 = brightness4 - fadeAmount3; // change the brightness of the third pair of candles for next time through the loop:
// reverse the direction of the fading at the ends of the fade for first pair of candles
if (brightness2 <= 0 || brightness2 >= 255) {
fadeAmount1 = -fadeAmount1;
// reverse the direction of the fading at the ends of the fade for second pair of candles
if (brightness3 <= 0 || brightness3 >= 255) {
fadeAmount2 = + fadeAmount2;
// reverse the direction of the fading at the ends of the fade for third pair of candles
if (brightness4 <= 0 || brightness4 >= 255) {
fadeAmount3 = + fadeAmount3;
// wait for 30 milliseconds to see the dimming effect
delay(30);
double* distances = HCSR04.measureDistanceCm();
Serial.print("1: "); // print out the value you read:
Serial.print(distances[0]); // print out the value you read:
Serial.println(" cm"); // print out the value you read in cm. Used to make a dimension on our leds turning on
Serial.println("---"); // print out the value you read:
delay(10); // delay in between reads for stability
if (distances[0] >= 2 && distances[0] <= 50) {
int brightnessOjo = map(distances[0], 50, 0, 0, 150);
analogWrite(9, brightnessOjo); // set the brightness of pin 9:
analogWrite(10, brightnessOjo); // set the brightness of pin 10:
} else {
digitalWrite(9,LOW); //turn the LED 9 off
digitalWrite(10,LOW); //turn the LED 10 off
Step 6: Weld the Cables and the Components
Recreate the scheme with welded cables, to apply the circuit into the prototype.
Step 7: Insert the Circuit Inside the Box
The led's cables must go through the candles, also in the inside of the skull, then they pass through the upper side of the grave holes.
Step 8: The End
There you go! The halloween project is completed!
