Halloween Solar Lights
Intro: Halloween Solar Lights
Halloween Themed Solar Outdoor Lights
STEP 1: Gather Supplies
1. Hollow plastic decoration of your choice. (It doesn't have to be a pumpkin. Plastic is better for letting light through, and it is usually safer.)
2. Solar stake light (I prefer the cheapest Walmart ones like these...)
Walmart #: 551425646
http://www.walmart.com/ip/Westinghouse-Turbo-Rocket-Solar-Path-Light-Black/24230342
3. Drill (any drill is fine for this weak plastic)
4. Step Drill Bit (mine was $8 on sale, you can also just use a 3/4 inch regular drill bit, but this is easier if you get a different size stake for some reason, cheap bits are fine because it's only plastic)
http://m.harborfreight.com/2-piece-titanium-nitride-coated-high-speed-steel-step-drills-96275.html?utm_referrer=direct%2Fnot%20provided
5. Find a work area where plastic shavings can drop safely and be cleaned up easily.
STEP 2: Drill Holes in the Bottom
Drill holes in the bottom of the pumpkin decoration. Make sure you get the same size hole as the width of the stake. A snug fit is better, but if you go to big then just put a zip tie below the decoration on the stake.
BE CAREFUL! Do not push so hard that you jab yourself with the drill bit when it pierces the plastic.
Note: If the decoration doesn't have a hole in the top or its not big enough, just cut it wider or drill it out. That's why I used pumpkins and not skulls.
STEP 3: Slide Onto Stake
Slide the decoration onto the led light stake. It should be a snug fit! If not, add a zip tie on the bottom.
STEP 4: Enjoy Solar Powered LED Halloween Lights!
You can place them in the yard or put them on the fence, or in a bucket in the window. you can even take them off the stake and place them along the window or fireplace mantle.
Note: The battery won't charge if the solar panel on top doesn't get adequate sunlight. If it stops working just set it outside in direct sunlight for a day to recharge.
3 Comments
Winterbird 8 years ago
Awesome!
mikeasaurus 8 years ago
This is a smart combination!
eagletech201 8 years ago
Cool idea!
