Introduction: Halloween Themed Loom Ring
Finished project <3 <3 sorry for the bad quality :(
Any loom kit will do. This is mine but the brand doesn’t matter <3
Step 1: Figure 8
First you have to take any color (I’m doing black, orange, and red for Halloween) and you twist it over your fingers to make a figure 8 shape
Step 2: 2nd Color
Then, you take your 2nd color and place it over top of your first color, but be sure that the colors don’t overlap
Step 3: Catch Ya on the Flip Side
Next, pull up on the bottom band from each side so it hooks overtop of the top color you are using
Step 4: New Color!
Then, add your next color over top but don’t overlap the colors because if you do, you won’t be able to hook the bottom band over the top band
Step 5: Up and Over
Then, you do the same thing as your first color and bring it over top so it hooks on
Step 6: Repeat
Repeat with as many colors as you want but DON’T take it off of your fingers until your done because you will lose your progress
Step 7: S Clip
This step is easy. Take an s or c hook. They should be somewhere in your kit
Step 8: Hook
Then, take the. Bottom loop of the S and hook it onto your top color on each side
Step 9: Hook Again
Then, take the bottom most color and use the other hook on the S to clip them together
Step 10: Hooray!!!
Yay! You finished! I made a ring but you can use these same steps and make a bracelet or a necklace as well!
Step 11: The End! <3 Hope You Enjoyed<3
I hope you liked the outcome and remember it takes practice to learn something new so just keep trying and I promise, you will get there
