Introduction: Hamster Climbing Frame
A fun obstacle any hamster will enjoy. Watch your hammy explore the tubes, climbing frames, hide-outs etc.
Step 1: The Materials
these are all the material you will require:
paper mashe glue
Popsicle sticks
toilet paper tube
stick
news paper
tape
Step 2: Paper Mache Popsicle Stick Walls
first, arrange 10 sticks next to each other
Secondly, put layers of paper mache on one or two sides (you can choose). Make seven walls
Thirdly, let it dry completely
Step 3: Preparing the Tube
Cut a hole in a toilet role tube
make sure your hamster can fit in the tube or in the hole
Step 4: Ladder
add a lader using popsicle sticks and two sewers.
stick it to the tube
Step 5: Create Walls
Hot glue the insides of the walls to get a rectangle. You can also hot glue the walls to make it more stable for your hamster
Step 6: Rectangle
Create another rectangle, but this time have the front glued with mesh wire so your hamster can climb up to the top. Then cut out two pieces of cardboard and stick them onto the top of the two rectangles.
Step 7: Slide
Create a small hamster slide by cutting out a cardboard piece and them taping the top with clear tape. Taping the slide ensures the hamster slides down.
Step 8: Sticking Them Together
Glue the cardboard toilet role including ladder to both rectangles so your hamster can climb through it.
Step 9: Small House
create a small house using popsicle sticks and glue them together with a small cardboard piece. Then attach it to one of the rectangle's.
Step 10: Finished Product
How your hamster can have fun a play in his/her hamster castle!
