Introduction: Hamster & Guinea Pig's Bedroom (castle Rarther)
My official website: www.udonbook.com/en
Things you need to build it.
1. a plastic food storage
2. a piece of wood
3. Anything cute you want to attach to the castle
2. a piece of wood
Step 1: Stone Age Method
Heat knife on a electronic cook top or use matches?
A little while, you will see the knife turning into red.
Step 2: Divide Plastic
Take adventage of the hot, use knife to cut plastic box. Do it gentle.
You may need to heat knife several times in order to cut all.
Step 3: Stick Them
Then, we need stick those cut thing together. Here, heat plastic will give a sharp better and firm result than super glue.
Stick is just the same when we divide it. Use knife to heat those to be sticked surface, heat it into soft (tender), and put 2 soft edge together. once done, rince by water. Those soft places will stick firmly.
I found a plastic roof and stick it to others by the same method.
Step 4: Make Up
That's what I get.
Use some sticker to beautify it.
Step 5: Raise the House Up
Find 2 bottle. Use a sharp knife to cut it. We need ust the bottom.
Attach the bottle to wood by screw. I rise the casstle to make it away from possible urine.
Step 6: Attach to Wood
Use super glus to attach all together.
Step 7: Newbie's Work Is Done!
The bedroom for my little Moony. The balcony on 2nd floor is for another small hamster.
