Introduction: Hand Dyed Mohair Yarn - Create Your OWN Goatally Gorgeous Variegated Yarn
About: Curly wool locks, loose curly wool, core wool, carded wool, and felting kits, mohair yarn, we also carry a wide range of miniatures and props so you can create a unique piece from start to finish! All of our l…
This guide will show you how to create a beautiful variegated mohair yarn!
There is the full kit available on my website, and I also sell the yarn separately
The full kit is available from:
https://www.tregaverfibreshop.com/product/yarn-dyeing-kit
You'll also need:
Tongs
Disposable gloves or dishwashing gloves
Spoon
Kitchen roll/towels to mop up any spills
2 metal saucepans or a saucepan and dish / bain marie
Vinegar
Step 1: Rinse Your Yarn Balls
After being spun, there is sometimes some dust or remaining lanolin in yarn, and to get best results from dyeing, you want clean, well washed yarn.
Soak them in hot water, pushing them under the water to get the air out, continue pressing down until yarn stops producing air bubbles.
Step 2: Wash and Soak Yarn
Add a tiny amount of wool safe laundry detergent (around 1/4 tsp for most brands will be well enough)
Let your balls soak in the soapy water for around 15 mins
Then run under hot running water to ensure all detergent has been removed
Step 3: Soak Before Dyeing
You'll need around 2 pints of very hot water, and add in 2 tablespoons of distilled white vinegar
Squeeze all the remaining water from the balls, then place into your container
Add in your 2 pints of very hot water, with the vinegar mixed in, and let balls sit for 15 mins, turn over, and then for another 15 mins.
Step 4: Prepare Your Bain Marie/heat Source
I use a metal saucepan and a pyrex type deep dish for this step.
Put a pint of water into a metal saucepan, and bring to the boil
Step 5: Sprinkle Your Dye
Using a teaspoon and the strainer, place a small amount of dye into the strainer and shake it across the dye
You'll need around 1/4 teaspoon for the top of the balls, so reserve the remaining 1/4 for step 8
Step 6: Place Dye Bath on Bain Marie
Carefully place your dye dish/pan on top of your pan of boiling water
Lower heat of the boiling water until it's just a soft simmer
Step 7: Squash the Balls, Leave for 15 Mins
Using a teaspoon, or tongs, gently press the dye down into the yarn
Leave the yarn in your dye pan for 15 mins
Do check that the water level in your bain marie is not disappearing, and add more water in if needed.
Step 8: Turn the Balls, Repeat Sprinkles
Using tongs, carefully turn over the balls, so the already dyed side sits in the water/dye mix
Use the rest of your dye to sprinkle across the other side, (as in step 5)
Leave for a further 15 mins
Step 9: Remove Balls and Rinse
Using tongs, carefully remove the balls from your dye bath into another container (for instance a washing up bowl)
CAUTION - your dye bath and yarn will be really hot at this point so do take the proper precautions when dealing with hot fluids
Run your hot tap into your bowl, and place the yarn underneath
You may want to keep this dye water to do another batch - just remember the colours will be less vibrant than your first batch! - normally we would leave the yarn in the dye bath until the dye is exhausted, but in this method there will still be some active dye pigments in your rinse water, so you can bottle it to use later, or even freeze it!
Step 10: Wash Balls Thoroughly and Dry
Once you've completed step 9, continue to allow water to run through the balls until the water runs clear
Then refill your container, with around 1/2 tsp of wool safe detergent, allow yarn to soak for 5 mins
Rinse balls thoroughly until there is no coloured water coming out from them at all
You'll need to ensure your yarn is completely dry before using it.
Place it in a warm, well ventilated area, such as an airing cupboard, and allow to completely dry.
Step 11: Congratulations! You've Dyed Your First Yarn for Your Project!
You can keep the dried yarn in the balls, or you can unwind them into a hank and hand twist them. Or make them into yarn cakes using a ball winder!
This step depends on your preferred way to use the yarn - if you prefer working from a ball, leave it as is, or wind to a cake, or hand twist into hanks
