Introduction: Hand Grenade Movie Prop
Being in the independent movie field is a pretty tough job. The costs for everything, then time put forth to create a good product. In hobbies such as this, D.I.Y. projects can come very much in handy. Props online can be very expensive, so making them yourself is a life saver. Especially when your wallet is anorexic, or when more is going out than coming in. No Action movie is complete with out a gunfight scene, and all gun fights need some grenades to make it look even more awesome. While being on a small budget, I created the Hand Grenade Prop. Seeing how i forgot to take pictures, I had to borrow them from Indymogul.com. But the same idea is still there. And your wallet won't take so much of a blow. In fact, if you HAVE to buy every material needed to construct this, it would only amount to about $10.
I introduce to you...
The HAND GRENADE PROP!!!
Step 1: What You Will Need
Quick List:
Empty Deodorant Can
Key Ring
Map Pin
Old unwanted MousePad
Flat Black Spray paint
Pliers
Sharpie
Scissors
Hot Glue Gun
Empty Deodorant Can
Key Ring
Map Pin
Pliers
Sharpie
Scissors
Hot Glue Gun
Step 2: Can
Make sure your can is empty first. After that is complete, rip the top lid off. This should leave an aluminum can top bare.
Step 3: Spray Paint
Now, You need to spray paint your can. Otherwise, your movie won't look as good when your soldiers are throwing Axe Cans at each other. The preferred color to go with is Flat Black, but if you want something otherwise go ahead, it's your movie.
Customize each grenade!!!
Using your sharpie, you can add a serial number along the top edges to make your grenade look more authentic.
Pull The Pin!!!
Take the key ring and pliers. Using your pliers, bend one of the ring ends out so it will easily fit into the top of your can. Surprisingly, the ring is just the perfect size to fit into the top of the can.
Pull The Pin!!!
Step 4: (Optional) Making the Grenade Look Futuristic
My purpose for the grenade was a futuristic movie. So, I needed to make my grenade look more like 2142 than 2002.
I took the map pin and cut off the pointy end, making the top of the pin flush. Using the Hot Glue Gun, I glued the pin top to the top of the can.
Feeling that the grenade was still too bare for any futuristic movie, I decided to glue hand grips to the sides. I took the old mouse pad and cut it into small rectangles. I Hot Glued them to the sides of the Can and left it at that.
Now go out there, pretend to blow stuff up and act like an idiot in front of a video camera!!!
