Introduction: Hand Held PC
Hi all..
This is one of my creations made out of boredom, it consists of:
- Vtech V Smile (case)
- 5.6" TFT LCD
- Dell Thin Client PC FX130 (1Ghz VIA,1 GB ram, 1GB SSD, Win XP nlited)
- Arduino Mini Clone
- 12V Lithium Rechargeable Battery
- Some putty
- Hot Knife
- Wrist action (sanding!!)
- Broken PS3 pad
- Hot Glue
Step 1: Get Your Stuff!
I got the Vsmile off Amazon for around £20, the Arduino set me back £6 and got it off ebay along with the thin client PC for £20. The screen cost me around £30 and the 12V battery £10 and got them off ebay also. I had a faulty PS3 pad which I used for the buttons and the analog stick.
Step 2: Rip Everything Apart, Cut, Mold, Stick and Sand!
I had an old PSP screen lying around so I used this as a template to cut the screen out. I cut the buttons on analog stick out of the PS3 pad out and used the excess plastic to fill in the gaps on the Vtech shell..
Step 3: Tweaks & Testing
The Ardunio clone didn't have any boot loader so I had to get the old trusty GQ4-X programmer and flashed the clone though the ICSP port.
The Arduino micro clone I had didn't have the functionality of changing the usb function other than a serial port emulation so I had to write two programs instead of one.
The Arduino program basically captures the buttons and analog stick and sends the data via serial
Analog X->A0
AnalogY->A1
Other buttons D0 <-> D8
Here's the code for the Micro
// These constants won't change. They're used to give names<br>// to the pins used:
const int analogInPinY = A0; // Analog input pin that the potentiometer is attached to
const int analogInPinX = A1; // Analog input pin that the potentiometer is attached to
int outputValueY = 0; // value output to the PWM (analog out)
int outputValueX = 0; // value output to the PWM (analog out)
int centreY = 0; //Callibrate
int centreX = 0; //Callibrate
int Ypos = 0;
int TempY = 0;
int NegY = 0;
int Xpos = 0;
int TempX = 0;
int NegX = 0;
// constants won't change. They're used here to
// set pin numbers:
const int buttonup = 2; // the number of the pushbutton pin
const int buttonright = 3; // the number of the pushbutton pin
const int buttonleft = 4; // the number of the pushbutton pin
const int buttondown = 5; // the number of the pushbutton pin
const int buttonDiamond = 9; // the number of the pushbutton pin
const int buttonTriangle = 8; // the number of the pushbutton pin
const int buttonRed = 7; // the number of the pushbutton pin
const int buttonYellow = 6;
const int buttonAnalog = 10;
const int buttonMode = 11;
const int ledPin = 13; // the number of the LED pin
const int led2Pin = A2;
// variables will change:
int dirState = 0; // variable for reading the pushbutton status
int buttonState = 0; // variable for reading the pushbutton status
int CTX;
int AnalogNegs = 0;
int PadMode;
int Fader = 0;
int FaderDir = 0;
void setup() {
Serial.begin(19200);
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
pinMode(led2Pin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonup, INPUT_PULLUP);
pinMode(buttondown, INPUT_PULLUP);
pinMode(buttonleft, INPUT_PULLUP);
pinMode(buttonright, INPUT_PULLUP);
pinMode(buttonTriangle, INPUT_PULLUP);
pinMode(buttonDiamond, INPUT_PULLUP);
pinMode(buttonYellow, INPUT_PULLUP);
pinMode(buttonRed, INPUT_PULLUP);
pinMode(buttonAnalog, INPUT_PULLUP);
pinMode(buttonMode, INPUT_PULLUP);
CTX = analogRead(analogInPinX);
centreY = map(analogRead(analogInPinY), 0, 1023, 0, 254);
centreX = map(analogRead(analogInPinX), 0, 1023, 0, 254);
Callib;}
void Callib() {
//TRY!! Callibrate Centre
centreX = map(analogRead(analogInPinX), 0, 1023, 0, 254); }
void loop(){
// read the state of the pushbutton value:
outputValueY = map(analogRead(analogInPinY), 0, 1023, 0, 254);
outputValueX = map(analogRead(analogInPinX), 0, 1023, 0, 254);
Ypos = 0;
NegY = 0;
TempY = (outputValueY - centreY);
if (TempY > 5 || TempY < -5) {
digitalWrite(ledPin, HIGH);
NegY = TempY < -5 ;
Ypos = TempY & 254;
Xpos = 0;
NegX = 0;
TempX = (outputValueX - centreX);
if (TempX > 5 || TempX < -5) {
NegX = TempX < -5 ;
// if (TempX < -83){TempX = -84;}
// if (TempX > 83){TempX = 84;}
Xpos = TempX & 254;
// Serial.println(TempX);
//Serial.println(Xpos);
dirState = 0;
dirState |= (digitalRead(buttonup) ^ 1) << 0;
dirState |= (digitalRead(buttondown) ^ 1) << 1;
dirState |= (digitalRead(buttonleft) ^ 1) << 2;
dirState |= (digitalRead(buttonright) ^ 1) << 3;
buttonState = 0;
buttonState |= (digitalRead(buttonTriangle) ^ 1) << 0;
buttonState |= (digitalRead(buttonDiamond) ^ 1) << 1;
buttonState |= (digitalRead(buttonYellow) ^ 1) << 2;
buttonState |= (digitalRead(buttonRed) ^ 1) << 3;
buttonState |= (digitalRead(buttonAnalog) ^ 1) << 4;
int d = (digitalRead(buttonMode) ^ 1);
if (PadMode > 0) {
//delay(30);
digitalWrite(led2Pin, HIGH);}
else{
digitalWrite(led2Pin, LOW);
//if (PadMode = 0) {analogWrite(A2, 0);}
if (d > 0 ){
PadMode = (PadMode ^ 1);
// // PadMode = 1;
// digitalWrite(A2, HIGH);}
//return;}
while ((digitalRead(buttonMode) ^ 1) > 0) {
} delay(3);}
buttonState |= PadMode << 5;
AnalogNegs = NegX << 0;
AnalogNegs |= NegY << 2;
Serial.write(0xFF); //sync
Serial.write(dirState);
Serial.write(buttonState);
Serial.write(AnalogNegs);
Serial.write(Xpos);
Serial.write(Ypos);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (dirState > 0 || buttonState > 0) {
// turn LED on:
//analogWrite(A2, 20);
else {
// turn LED off:
digitalWrite(ledPin, LOW);
Callib;
// delay(3);
delay(2);
}I've used a sync byte to synchronize the serial data to the FreeBasic program. I also added an LED that sits in the centre button which is used as a 'Mode' button to give another layer of control.
The FreeBasic program converts the serial data from the Arduino into to keyboard keystrokes, it's run upon start-up of windows as a background task.
Thanks to Ben Heck for the inspiration!!
