Introduction: Hand Made Pocket for Molle System, Part of Pouch Wheelchair Accessories
The sustainable Molle system pocket made from recycled materials is part of Pouch Wheelchair Accessories. It can connect to Molle systems or can be attached to a wheelchair if you are interested here is the link https://www.instructables.com/POUCH-Wheelchair-AccessoriesMolle-System-Sides/
- A pair of thrifted pants
- Used 93 cm of webbing
- 6cm of velcro (can also use snap buttons)
- Lighter or candle/matches
- Recycled fabric of your choice
- 25mm Webbing (I reused some webbing from backpacks/bags and also bought some black webbing from Bunnings) https://www.bunnings.com.au/grunt-25mm-x-10m-black-poly-webbing_p4310851
Tools
- Pins
- Ruler
- Pens/Pencils
- Fabric and Paper Scissors
- Iron
- Needle and Thread
Step 1: Template
Print out template for pocket
(use the corresponding left or right side pocket if you are using it to put on to the Pouch wheelchair Molle sides )
Step 2: Cutting and Ironing Material
- Using the Pocket template, cut the recycled fabric of your choice by hand or with a machine
- Iron along the dotted lines as shown in the template
Step 3: Straps to Connect to Molle System and Sew Pocket
- Collect materials: Webbing, needle and thread, velcro or snap buttons and lighter
- Cut 31cm pieces of webbing for the amount of straps you want (I used five straps, the straps are placed 2.5cm apart)
- Add a 2x2 cm square of velcro or two snap buttons to opposites sides of the webbing
- Burn both of the edges of the webbing
- Connect the velcro and flatten the webbing to make sure it stays flat burn the edges, sew on the velcro
- Pin the straps 2.5cm apart and sew the back rectangle to the bag
- Sew inside seams of the pocket
- Sew side seams of the pocket
- Sew velcro
- finish Molle Pocket
- (Optional)Connect straps to the Pouch Molle system sides
Step 4: Enjoy
Hope you enjoy using your sustainable Molle bag, Let me know how you go!
If you are interested in making more items part of POUCH designs
