Introduction: Hand Sewn Pixel Shirts
These shirts are an incredibly fun way to celebrate your favorite retro games! The pixel look brings it an edge and everyone will be asking where you got it from!
What you will need:
- a plain t-shirt
- waste canvas
- embroidery floss
- size 20 embroidery needles
- light weight fusible interfacing
- lots and lots of time
Step 1: Plan Your Design
When creating my designs I like to keep the color scheme very simple, the more colors you use then the more thread switching you will need to do. For your first shirt use at most maybe 10 colors. Plan out your design pixel by pixel on the computer in "Paint" and be sure you view the ruler and grid tools. When you are done planning print this out to use as a reference while you stitch!
Step 2: How to Make a Stitch
Each pixel makes an x.
To sew that you begin from the inside/back of the shirt and poke the needle up through the bottom left corner of the pixel you are working on. Then sew through the top right corner. You now pull the needle through from the inside of the shirt to the bottom right corner. Finally you sew through the top left corner of the pixel and that square is now complete!
If this is your first time cross-stitching, practice on some scrap fabric first until your stitches look consistent.
Step 3: Get Going!
Have your reference close by and work one color at a time.
Step 4: Check Your Work
Be sure that the inside of your shirt remains neat and free of any loose threads (feed them through the stitches on the back as you work), you want your shirt to last a long time and through much wear and tear.
Step 5: Nearing the End
After hours and hours, days and days, you will finally almost be done! Only 2 more steps left!
Step 6: Pulling Out the Canvas
This is the most difficult part of the project. It requires patients and perseverance. If you stitched very tightly then this step is even harder for you. One at a time you must pull out the strings of the waste canvas, I've found that it is easier on the fingers if you use needle nose pliers to grip the strings because there are a lot!
Step 7: Back Your Shirt
On the inside of the shirt I used a light weight fusible interfacing. I cut it slightly larger than the size of the design itself and simply ironed it on. This keeps the threads from coming loose and it also provides much more comfortable wear!
