Introduction: Hand Tool Build Off 2017
This is my entry into the hand tool build off 2017!
I made a chisel from a piece of 2x4 .
Im also throwing in a strop i made and some polishing / stropping compound that i use.
A great project and i love how its turned out , im a little gutted to give it away but if your just starting woodwork or using hand tools then this will hopefully be perfect for you. I know i would have killed for a sharp chisel and a way to keep it sharp when i 1st started.
To try get your hands on this check out the links below :-
James Wright -
Mitch Peacock -
As Always I hope you enjoy!
Please leave a like, share & comment.
And subscribe for more like this!
Watch my builds - https://www.youtube.com/channel/UCRMjvilGRdZxHqr3...
Follow my work on Instagram - https://www.instagram.com/ggwoodprojects/
Help me make more projects- https://www.patreon.com/GGWoodwork
OR
One time tip - https://www.paypal.me/GGwoodwork
Thanks
GG
Step 1: Cut & Square
I started with an off cut from a 2x4 and lay the chisel blade out and traced a rough handle shape.
Then i cut out the rough shape and moved onto squaring it up
Step 2: Shape
Once i had it flat and square i went onto shaping it.
I didn't want just a normal round handle or a square handle so i went for an almost round one.
First i clamped it up in my vice so one of the 90 degree edges was facing up, and planed that down, i then rotated it 45 degrees and did the same.
Once it had no sharp 90 degree corners on i rotated about 22 degrees and planed both sides of the lines left.
Its really hard to explain but i have a video you can watch if you get stuck.
This left me with a sort of round shape but with about 16 or so sides ( i didn't count)
This felt great , it was round enough to feel comfortable but had enough grip on so the chisel wouldn't slip out of your hand (hopefully)
Step 3: Rasp & File
Next i moved onto the top of the chisel, i wanted it to slightly slope inwards towards the bade of the chisel, so i measured the very end of the chisel and use a rasp and file to round it over .
Step 4: Sand
Next is everyone's favorite , hand sanding!
The hand plane left a pretty good finish so i just sanded at 500 grit
Step 5: Restore Chisels
The chisels that i bought for this where not in the greatest shape so i used a wire wheel on the drill to smooth it out and get rid of any rust spots and machine marks, then i used 500 grit and 1,200 grit sand paper to give it a bit of a polish.
Step 6: Drill & Fit
Next was attaching the handle, i measured the chisel tang and used the same size drill bit to drill out a hole, and epoxy'ed the handle in place.
Step 7: Finish
For a finish i used 2 coats of spray lacquer, sanding at 500 grit in between coats, making sure i didn't get any on the blade.
Then i sharpened and stropped the blade to a razor sharp and mirror finish so its ready to use straight out of the box.
Step 8: Job Done
Thats it , job done.
The handle feels great in your hand (my hand anyway) and had a nice resting spot for your thumb so you can apply a lot of pressure pretty easily.
In with the chisel im giving the small strop i made and a bit off the polishing . stropping compound that i use so even if you dont have a whetstone or diamond stone you can keep the chisel razor sharp.
I had a great time making this and i like the style and feel so much im going to do the same on my own chisels.
I hope whoever ends up with it likes it as much as i do, just be careful the blade is ready to use so its very sharp!
check out these links to the competitions to try get your hands on this! :-----
James Wright -
Mitch Peacock -
I hope you enjoy!
Please leave a like, share & comment. And subscribe for more like this!
Watch my builds - https://www.youtube.com/channel/UCRMjvilGRdZxHqr34QKzB_Q
OR
Send me a tip - https://www.paypal.me/GGwoodwork
Thanks
GG
