Introduction: Hand Tracking With Media Pipe and Arduino to Control the Color of an RGB LED
Lets create a project that uses hand tracking to change the color of an LED. This is project will explore using Python and the Media Pipe library to track the position of the hand. After get the position we can then communicate with the Arduino through a wire, also know as serial communication! After the Arduino receives the data from the computer doing the hand tracking we can change the color of the LED.
- A laptop that can connect to an Arduino using a serial cable
- An Arduino of any type, in this case I am using an Arduino Nano
- Serial cables, 4 are need one for powering the LED and 3 for communicating the color
- An RGB 4 pin LED
- Breadboard
- Serial Cable (The cable must be able to transfer data)
Step 1: How It Works
For code and additional file details refer to my github: https://github.com/OwenTheGreenBean/HandTrackingColor
Step 2: Assemble the Arduino Circut
We will be connecting the RGB LED according to the diagram. These pins can be changed as long as you update the pins in the Arduino code.
Step 3: Upload Arduino Code
Connect the cable from the Arduino to the computer, make sure that you have selected the correct port. Note the name of this port for later when we will be modifying the Python code. Using the Arduino IDE we can upload the following code to the Arduino by using the upload button. The Arduino file is attached below
Step 4: Python Code
We will now setup the Python Code. To do this download the Python file that is attached and then make sure the librarys are installed. We can do this with the commands.
Now that serial port we got from Arduino IDE comes to use now. For the Python program to successfully communicate with the Arduino the correct port must be selected. We will change this line in code to match the serial port we got from the Arduino IDE. Only changing the text inside the ' '.
Also! Im am using my laptop that has a built in webcam if yours does not and you are using a USB webcam you can change the 0 to a 1. (0 Being laptop camera and 1 being external camera)
Step 5: Run
- Make sure the Arduino is connected to the correct port
- Close the serial monitor in the Arduino IDE or just exit Arduino IDE application
- Navigate to the directory that the Python file is stored in and then using the command
- You will then have a window pop up that will be tracking your hand and controlling the LED!
