Introduction: Handheld Edgelit Light
Create this handheld edgelit light and amaze all your friends with hoographic images of engraved plexiglass!
Step 1: Materials
Arduino Nano, Solderless Male-Male Wires, LEDs, 4-pin Solderless Button, Solderless Breadboard
Step 2: Wiring Up the LED
Wire as shown (some wood backing already attatched)
Step 3: Program
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 13; // the number of the pushbutton pin
const int ledPin = 12; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
void setup() {
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
void loop() {
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
} else {
// turn LED off:
digitalWrite(ledPin, LOW);
Step 4: Assemble Wood Housing
Assemble as shown with hot glue gun (you may assemble differently, but make sure you leave a hole for the button and power cable.
Step 5: Engrave!
Use a laser cutter or engraver to create personalized designs tailored to your special light!
