Introduction: Handmade Wooden 9 Blocks Wall Clock
It is my second wooden wall clock.
Step 1: What Do You Need
1. clock mechanism
2. some wood
3. drill with a drill bit paddle (pic.3)
4. wood stain
5. nails
6. glaze with mettalic effect/ optional wax
7. sander
Step 2: Preparation of Wood Blocks
First made a solt in the center wood so that the clocks mechanism can fit in.
I didn't had right tool to do a hole - firs I made a hole using a drill bit.
Then I cut off requred wood blocks- 9 sections.
Next sanding the blocks.
Arranged them into square and marked them which one goes where.
Paint wood stain.
Step 3: Fixing Wood Blocks
Prepare nails: cut the head.
Next: painted and dry blocks connect with nails- like a picture.
Step 4: Surface Finish
I used to finish the surface - wax timber.
After applying waxes and dry (min. 2 horus) polished used plastic brush.
Because of the unsatisfactory effect- I painted metalic glaze.
Then I installed a clock mechanism- in the central block.
Step 5: Assembly Clockwise Adn Done
At the end - mount clockwise and ready.
