Introduction: Handpan/Pantam Stand
Very easy to build stable stand for handpans and metal tongue drums.
Fits 53 and 46 cm models including bottom notes
SECURITY NOTE: To use the tools described here please refer to their instructions for use. Only use them if you are able to handle them safely. Always pay attention to safety for yourself and others. I assume no liability for injuries or damages to your instrument or other objects!
Material:
5-6 cm hinge
2-3 mm rope
Some small screws with washers and nuts
Board of plywood 52 x 37 cm, 10-12 mm thick
Tools:
Work table
Jigsaw with narrow fine saw blade
Drilling machine
Screwdriver
Wrench
Lineal
Pencil
Sandpaper
Step 1: Mark the Wooden Parts
Draw the shape of the two parts on the wooden board. In picture no 1 you can see the most important dimensions. They apply to a 6 mm board. I used this for my first version because I had no thicker plate at that moment.
If you use 10 or 12 mm wood, what I recommend, the parts can be marked correspondingly narrower.
It is advisable to first saw out the parts a bit larger, afterwards they can be easily reduced with the jigsaw if needed.
Step 2: Saw the Panels
Saw out the two pieces of wood with the jigsaw.
This works ideally with a saw holder, where the saw is attached to the table and the wood can be guided precisely.
Then round off the corners and edges with sandpaper.
Step 3: Assembly of the Hinge
Mark the hinge holes on the inside of the wooden pieces and drill the holes.
Attach the hinge to both pieces of wood with the small screws, washers and nuts.
Step 4: Attach 2 Chords
Drill 4 holes. Fasten 2 cords so that the distance between the wooden parts on the ground at the front is about 35 cm.
Ready! :)
