Introduction: Hanging Plant Holder
I always have lots of potted planted taking up all of my very small backyard space. I wanted to make something that would take advantage of vertical space.
You will need:
4 mm Crochet hook
1 (small) Skein of 100% cotton yarn (such as lily n’ Sugar brand)
Scissors
4 inch high planter (10.5 Cm)
Key chain ring
Burlap
Potting soil
Perlite
Sand
Succulent bud
A hook or hanger you can mount onto your house or deck
Step 1: Start Magic Circle
Use the magic circle method and single crochet 8 stitches.
Step 2: Double Crochet
Double crochet 2 stitches into the previous row. You should have 16 stitches. Remember to crochet over the tail to avoid slipping. (I did leave it at the end of the second row to make it easier to find the start)
Step 3: Build the Bottom
Crochet 2 Rows using the double crochet stitch. Work two into every other stitch.
Step 4: Work Up
Begin working up by completing 1 row without adding stitches.
Step 5: Work Up and Out
Add 2 stitches in each row until you  have crocheted about 5 inches from tip to top. (see diagram above)
Step 6: Sew Excess
Fasten off your work and sew the loose seams
Step 7: Cut Strings
Cut 14 2 ft (61 cm) long strings. Divide them into pairs.
Step 8: Attach Strings
Attach each pair of strings by pulling string ends through a loop.
Step 9: Finishing Touches-Cobra Knot
Using the “Cobra knot”, Paracord about an inch of the bottom
Step 10: Finishing Touches-Ring
Attach a metal ring to the top and fasten.
Step 11: Attach a Hook to House
If necessary, mount a hanger in the desired area.
Step 12: Plant
Plant your succulent by mixing water, perlite, and sand until you reach a sandy consistency. Add the burlap in the bottom, pour in your soil mix, and plant your desired succulent.
Step 13: Hang!
