Introduction: Hanging Desk
This is my hanging desk! :)
Its suspended 110 cm (43.3 inches) over the floor, almost standard bar height.
Four bolts with eye-heads are screwed into the beams, and through the are running 2 mm steel wire.
The surface itself are made from 18 mm MDF (Medium Density Fiberboard) and just sprayed with your regular spraypaint.
In the corners, be aware that most brick houses arent perfecly 90 degrees, so make a little 45 angled notch of about an inch.
This was a great weekend project, and the thing that took the longest was for the paint to dry.
Use photos however you see fit.
If you dont happen to have the kind of supporting beams i have here, dont worry!
In most houses, use a stud finder to locate the supporters for your ceiling.
!!Check for electrical stuff first!!
Be creative, and do steal all of my ideas.
If you have questions, leave a comment!
