Introduction: Hanging Oillamp/bug Repellent
This is an adaptation of the many other oillamps shown on here or you can leave off the lid and put a candle in the jar or even a small plant
Step 1: You Will Need
Your going to need,
a jar with a lid
wire, Im using floral wire here but you can use electrical wire
something to cut the wire
A wick ( I took one from a tiki torch that melted on me)
citronella oil or regular lamp oil
a jar with a lid
Step 2: Making It Hangable
You will need 3 or 4 pieces of wire around 30" long, I doubled up the floral wire for strenght and to add a little something to the finished product.. Pretty simple, wrap the wire around the jar below the screw cap and twist to hold it tight
Step 3: Repeat
repeat the above step 3 or 4 times depending on how many wires you want your lamp to hang from
Step 4: Connect
Now connect the wires at the top, making sure the lamp will hang level, add another short piece as a loop to hang from
Step 5: Make It a Lamp
Drill or cut a hole in the lid to fit your wick
Step 6: Assembly
cut your wick to lenght and insert in the lamp, fill the jar with oil and let the wick soak for an hour or so
Step 7: Hang It Up and Enjoy
Find a place in a tree or other location to hang your lamp and enjoy
