Introduction: Happy Face
This is a giant wall mount spinning happy face :)
Step 1: Parts
Six snow mobile bearings (inside diameter 20mm)
Twelve 3/4" #6 flat head screws
18" x 20" 1/2 inch thick plywood
paint
3d printed gears and bearing holders (each gear and bearing holder takes about 7 hours to print--this is not an overnight enterprise)
Step 2:
The gears were designed in Fusion. Go to "add ins--spur gears" to get to gears.
After I created a gear, I imported it into Tinkercad (20% size), then made the gear 10mm deep. In Tinkercad, I combined the gear with the "axle piece" to create a finished gear. The axle piece is threaded to allow for securing to the bearing in a later step.
Step 3:
Take the top bearing support and insert a bearing.
Step 4:
Take the lower bearing support and push it onto the bearing.
Step 5:
The bolts (printed at 96% size) thread into the bearing supports and secure the bearing.
Step 6:
The gear lock (printed at 100% fill and 95% size) threads into the gear and holds it in place.
Step 7:
Cut and paint the plywood backing. Fasten the gears one at a time using the 3/4" screws.
Step 8:
Cover the wood screws by threading in the cover caps (printed at 90% size).
Step 9:
This should complete the wall art spinner--try to walk past without turning a gear :)
