Harbor Freight Drill Charger Mod
Intro: Harbor Freight Drill Charger Mod
WARNING: PERFORMING THIS MOD WILL PROBABLY COMPLETELY VOID ANY WARRANTY YOU MAY HAVE.
You may notice the charger included with Harbor Freight rechargeable drills (at least the Drill Master 66965) is not a "float" charger, meaning you CAN NOT leave the battery on the charger for too long otherwise you will destroy the battery.
This Instructable fixes this issue.
This limits the charging current to approximately 100 milliamps which is less than 10 % of the 1200 milliamp rating of the battery thus OK for a constant “FLOAT” charger. Note - Allow no less than 14 hours for full recharge of a fully discharged battery but you may leave ON after that time.
STEP 1: Open the Charger
Turn the charger base over. There are 4 screws. Take them out. Remove bottom of charger.
STEP 2: Make Your Resistor
Take 3 Radio Shack 10 ohm/ 1 watt resistors (Radio Shack # 271-151, BUY 2 PACKS) clip them short, and solder them in series.
(yes, I know my soldering STINKS.) Cut a piece of shrink tubing to cover the resistor and heat to shrink around it.
STEP 3: Insert Resistor Into Charger Base and Close
Clip red wire in the charger. Strip the covering to expose appx 1/4" of the wire on each.
My pictures aren't great but I forgot to add shrink tubing to one end to cover the solder connection.
Shove it in and replace the cover.
21 Comments
AlK6 8 years ago
I had been doing this type of mod on the current series of DrillMaster Drills that come with battery 68413 and use the 68420 model charger. It was a manual charger just like this one that would burn up quickly if left in for more then a few hours, but now it looks like Harbor Freight finally got a automatic charger is their latest series of drills. I got one off of ebay and I tested it and it works! It really does shut off after the battery is charged! I got another on the way now too. I think you can find it just searching for drillmaster automatic charger.
SteveM16 9 years ago
Why not just spend $5 on an electric timer at Harbor Freight, plug the charger into it, and recharge the battery for only 4-5 hours?
xrobevansx 9 years ago
Enduroboss 9 years ago
I did this mod. Results were a bit different. BEFORE mod - 1.14A (1140mA), AFTER MOD - .562A (562mA) - Measured at the battery posts that touch the battery. Voltage 30.5v
Battery pack is 1300mAh so full charge should be reached in about 2.5 to 3 hours? Need to add more resistors to bring it down to approximately 100mAh
So it cut the current about 1/2. Still a bit high. Interestingly, the charger output is listed on the charger as 400mA
Harbor Freight Drill 69651 (Purchased Dec 22, 2014)
Charger Model Number XR-DC240400
ron.garzolini 9 years ago
These chargers must be made in various locations. I have two
of them & the output on both was 300 - 310 mA@35.2 V.After reading the posts here, I added 410-Ohm resistors to one charger (since they
come 2 to a package, no sense in wasting the other one)Now the unmodified charger puts out 310 mA initially
& tapers down to 240mA after about 1/2 hour.
The modified
charger puts out 140mA tapering down to 130 after 1/2 hour.To be on the safe side I labeled them MAX 5
HRS & MAX 10 HRS respectively.Thanks
for the advice guys.
Harbor Freight Drill 68287 (Purchased Dec 18, 2014)
Charger & batteries both numbered 69652
Chargers marked24V DC400mA
wario235 10 years ago
I just got my hands on a HF drill (68851) and it came with a really crappy charger (68859). I'm really careful about reading reviews on HF stuff before purchase (thus that specific drill). Reading the reviews on the charger though, say very similar things to the complaints you remedy in your instructable here.
1st night charging the battery, I only charged it for an hour, and had to unplugg it for 20 min to let it cool; it was already getting that electronic burning smell.
Would I need to plug my information into an equation for a different amount of resistance to drop the current to "Float charge" specifications? Specs: 7.2-24VDC, 1.3A.
Not sure what the output Amperage is on that model. You need to know what it's delivering to the battery. Then add resistors accordingly.
http://www.sengpielaudio.com/calculator-ohmslaw.htm
ladyfb 9 years ago
I cannot locate any type of connection in which to insert the adapter plug into the base (battery section). The box pictures a connection on the certer of the back but no opening exists anywhere in which the plug would fit.
What model do you have?
jongscx 10 years ago
gsnoorky 10 years ago
Putting in a switch may not prove worth it: HFT now has these for sale--separately boxed--discounted to move for about $5. Thus, one may leave one as is, while modifying the other--marking one or both chargers accordingly. (Remember, this is "Drillmaster"--not "Chicago Electric.")
Given that I screw up, somehow, my original charger still should work. I believe that my chargers are both 68420 models--thus, I'll relate later whether the mod works well or not....
xrobevansx 10 years ago
bigun913 11 years ago
gsnoorky 12 years ago
Thanks, also, kill-a-watt: Many of us need to be reminded of the quality way--the right way to do such things--that saves future aggravation--and, time.
Thanks for this: It would have cost the PRC a fraction of a cent to do this. If HFT had insisted upon this from the PRC co. involved, they would have avoided great resentments and carping about this product. It seems that HFT would desire less resentment and more public satisfaction--spending a few cents and maybe even adding a $ to the purchase (for their trouble) would smooth things over with the public. It seems to me, at least, it's in their best interests.... Anyway, I'm certain that this solution may be easily incorporated into other such products which people buy. (I know!: It is what it is!)
PRC cos. copy and steal ideas from each other endlessly: Something which costs $20+ at a certain retailer costs $5+ elsewhere. (I can submit easy examples, if desired: I think that I'll join!)
I'm moving, and we have to sell our property, so I won't have as much time as I desire to contribute at this point. I can tell that the contributors here are great, though!: Thanks again! I wish that I had known about this site years ago!
Phil B 13 years ago
xrobevansx 13 years ago
kill-a-watt 13 years ago
Your soldering looks pretty good to me. There is, however, a lot of solder. Even though the picture is blurry, I can see that enough heat has been applied so there isn't a "cold joint" here.
A passive component like a resistor is the perfect thing to practice on though. As a practical manner you don't have to worry about too much heat destroying the part.
Next time: 1) twist the leads together to make a mechanically strong joint. 2) "tin" the tip of your soldering iron, then wipe it on a sponge to clean it. 3) add one "drop" of solder directly to the freshly cleaned tip 4) touch the tip of the iron to the future solder joint and hold it there until you see that drop of solder wick into the joint 5) add a small amount of additional solder, but allow the joint (not the iron) to melt the solder and allow it to be wicked into the joint 6) remove solder and iron, allowing the joint to cool to solid without a bump or jarring,
Phil B 13 years ago
