Hard Boiled Eggs With Bacon INSIDE
Intro: Hard Boiled Eggs With Bacon INSIDE
That's right, watch their faces as they crack and remove the shell from one of these eggs and find that the bacon is already in the egg!
I made this at TechShop www.techshop.ws
STEP 1: Materials & Equipment
Laser cutter (my TechShop has a Trotec Speedy 300)
Toothpicks
Pin
Cling wrap
Duct tape
Pot
Raw eggs
Cooked bacon
BONUS: For pre-scrambled eggs
Plastic Easter egg
1/4" bolt, washer, and nut
1/4" drill bit
Small piece of foam
Electric drill
This instructable assumes some basic familiarity with CorelDraw and a laser cutter.
STEP 2: Design the Egg Labels
If you want to completely surprise people, skip both this step and the engraving step later in the instructable. However, I thought it would be fun to label each kind of egg and see the puzzled look on their faces when they picked up an egg.
You can engrave about a 1.5" x 1" area on the egg without a rotary attachment for the laser cutter. Select a blocky, bold font so that the text will stand out on the egg. Adjust the font size to be a little smaller than that area. Then draw a rectangle around the text, and add scalloped corners for effect. Use black lines and text so that the laser cutter knows that you want to engrave and not cut the egg.
STEP 3: Design the Egg Access Hole
STEP 4: Laser Engrave and Cut the Eggs
STEP 5: Add Bacon to the Egg
STEP 6: Wrap the Egg and Hard Boil It
STEP 7: Clean Up Any Leakage
STEP 8: Serve and Amaze!
Serve and watch their expressions as they have their first "bacon in a hard boiled egg"!
STEP 9: Bonus: Scrambled Eggs
What if your friends prefer scrambled eggs and bacon? That's another step that involves power tools in the kitchen!
Drill a hole in a plastic Easter egg, add a bolt, washer, and nut. Stick this in a power drill and spin away for a few minutes. This will scramble the egg in the shell!
STEP 10: More Practice Needed...
I did puncture the yolk first after adding the bacon and before spinning. It turns out my scrambled eggs were a little runny, and need to cook a little longer. I'll have to try again!
30 Comments
spark master 8 years ago
I like the concept and propose an modification for it. A very good way to make HB eggs way , many say, isto put raw eggs in cold water bring to boil , 1 minute boil, turn off heat and let sit covered for 17-19 minutes. This can be good for less cracked leakier eggs.
Older eggs peel easier, and thick shelled ones are better as well, they keep better at room temps.
Hard boiled eggs can be frozen and then used as "ice" or at least to keep themselves cold for transport, (camping/overnights/car trip). Again, cooked unbroken, eggs keep well at room temps for a few days. With bacon added and big hole who knows, but frozen...
Plus frozen eggs can be used in trebuche's and true sling shots! Only kidding....
SamirA2 9 years ago
oh boy let me just whip out my handy dandy lasser cutter
walshlg 10 years ago
LOl just saw the egg scrambler for $18 on KickStarter
jarikcbol 10 years ago
you can do the same trick with a stocking. you put the egg in the stocking about halfway down, hold the toe of the stocking in one hand and the top in the other, and wind it up with sort of a 'swing a jump rope' action until it is tightly twisted, then pull your arms apart to make it untwist super fast, this spins the egg and scrambles it. if you search scrambled egg in shell on youtube the 5th result (as of 5-13-14) shows this trick.
Raitis 10 years ago
I'm not sure if it's me or some eggs are really hard to scramble while raw. I tried doing that to some of them before Easter hoping to surprise people, but pulsing drill on full speed for several minutes didn't even weaken the yolk, let alone scramble the egg.
What I have noticed while frying eggs is that some of them have considerably more runny yolks and whites after splitting than other ones, which just don't spread that much and it somewhat correlates with shell thickness. So be advised, try and find out.
As for instructable - well done!
soy_bean 10 years ago
Could it be that the egg inside is slipping and not spinning along with the drill at higher speeds? You could try putting double sided tape on the inside.
Raitis 10 years ago
I used an egg whisk mounted in drill with egg inside of and powertaped to whisk, so highly doubt that it was loose there. Oh, and the drill I used wasn't even cordless, so probably had a higher range of speeds and torque, but that didn't help either...
annabenson6 10 years ago
craft-n-genius 10 years ago
WOW!!!! marvelous job!
When I first saw this on the news letter, I was a more than a little confused. But now that I know.... that is SO cool! I am voting for you and I hope you win! :D good luck!
Kaiven 10 years ago
NightHawkInLight did a scramble egg thing using a sweater, for those interested.
canida 10 years ago
Nice work! I'd imagine that those without access to a laser cutter could cut a nice porthole with a Dremel.
valkgurl 10 years ago
This should be obvious but you will need a plastic egg BIGGER than your real egg ---And I would tape the seam just in case of shell failure! Most commercial eggs have extremely fragile shells--this would work better with farm eggs---some shells from our hens are actually a little tricky to crack and seperate!
noelsgordon 10 years ago
Please provide a link to the Laser Cutter you have.
lbrewer42 10 years ago
Years ago I accomplished the bacon egg with a razor blade! But unlike the laser, I couldn't etch them. For fun I also made an agg full of cereal, and one full of milk to put on the cereal. I also painstakingly took the time to stuff already scrambled eggs into one eggshell. But the look on the person's face who I prepared them for was proceless.
ladesco 10 years ago
clever! now, here's how to add a little more "clever"... google search for "the goose" egg spinner for going pro. but, you can simply use a long sleeve of a t-shirt, knee high sock or leg of old pantyhose. put the raw egg in the middle of the "sleeve"... secure with rubber bands on each end. then spin it around a bunch of times (center force will bounce and break the yolk and mix it up with the egg white. now, continue with this process for adding bacon... voila! a scrambled egg and bacon!
ClareBS 10 years ago
Those eggs are cool, I love the "labels". Instead of boiling, try steaming them for the same amount of time, they will be easier to peel and look even better.
tisaconundrum 10 years ago
Here is a possible appending idea for the scrambled egg part. You can use a sweater sleeve to get the egg to scramble.
telorand 10 years ago
Exactly what I thought of, too.
sfox16 10 years ago
That looks so disgusting lol
steve
www.scrabblecheat.com
