Introduction: HDD Magnetic Doorstop
Simple doorstop made from powerful magnets, recycled from a broken hard disk. Works best with wooden floors and lightweight doors.
Step 1: You Will Need
Tools:
Screwdriver or battery drill
Pencil
Old chisel or door wedge.
Materials:
Old hard disk (To cannibalise for parts)
Pencil
Materials:
Step 2: Disassemble Hard Disk
First you need to open your hard drive up. You'll probably need to use some torx bits and a screwdriver to prise the case open. I've included a few examples in the images below.
(Warning: The hard drive is going to be useless after this step. If you don't have an old one to hand, there are places you can find them. I've seen very cheap, old rubbish hard drives for a few pounds each at PC fairs, and also the electronics department of an army surplus depot).
Once you're inside, there should be a few screws securing the magnets and the read write head. Hard disks obviously vary a lot from one manufacturer to the next, but they all have a similar layout and design. It's a fairly straightforward disassembly job to get the magnets and read wirte head loose, then separate them all.
Hard drive magnets are ideal for this project. They're strong, and they're glued very solidly to backplates that already have handy mounting holes. Be careful with them though, because they can hurt your fingers if you're not. Here's a quick demo of the speed and range at which they can snap together:
Step 3: Remove Door, Add Magnet, Rehang Door
Carefully remove your door, propping it up at the bottom with an old chisel, door wedge, offcut of wood, etc. To minimise strain on the hinges, keep it supported and leave a screw in each hinge until you're ready to get it down quickly.
Once you've taken the door off, screw one of your magnets into the bottom near the hinge side, as shown below.
Rehanging the door should be fairly easy. Support it with the wedge/chisel while manuvering it into a position where the hinges are more or less aligned properly, then start putting screws back into the holes thy came from. Screw them all in halfway, then you can gradually take turns tightening them and adjusting the position of the door. Just take your time and keep tweaking the position; its unlikely to align perfectly at first. When it's aligned closely enough, the screws will pull the hinges back into the right place.
Step 4: Mark Floor, Fix Second Magnet
The nub shown in the photos on the last step was put on closest to the side of the door that faces in, because that makes this step easier by giving an obvious reference point for marking the floor and aligning the magnets. Magnet backing plates don't always have nubs, but in this case both plates did and they aligned when the magnets were facing each other.
So:
Put your pencil against the door, with the point touching the floor. Close the door, and it will mark a curve out, allowing you to align the bottom magnet with path of the one fixed to the door.
Now, decide where you want the door to stay when it's open. I went for less than the maximum travel of the door because I have some shelves in the way.
That's it, you're done! Once you have it fixed down, as long as the magnets are close enough (and you'd need a pretty big gap or heavy door for them to be ineffective), they will catch the door and gently hold it in place.
I've put some videos below to demonstrate the pleasing wobble this creates, and I've also detailed a couple of optional extras in the next step.
So:
Step 5: Extras
I did two things to make this better: Raise the floor magnet, and pad the door.
There was quite a big gap between the door and the floor. Not enough to make the magnets ineffective, but enough that I decided to increase the power by raising the floor magnet, fixing it through two washers at each end.
Also, since I wanted the door to open as far as possible but not bang against the corner of my shelves, I stuck a semicircle of felt padding to the bottom of the door where it was hitting. I can now throw the door open, and it will hit the shelves then come to a halt over the magnet almost silently.
