Introduction: Hard Drive Desk Clock
Convert an old harddrive from a decktop PC into a cool looking desk clock.
Step 1:
Locate an old hard drive.
I found one with actual screws securing the case and circuit board.
Purchase a clock mechanism with a 3/4 inch long shaft from a hobby store.
Step 2:
Remove the case and circuit board.
I could not remove all the screws, so I was forced to pry off the cover.
Be carefull not to damage the insides.
Step 3:
The clock required a 1/4 inch hold for mounting.
You need to remove the hard drive platters and spindle.
I used a T6 torx wrench to remove the 3 screws.
Step 4:
Expand the hole to 1/4 inch in the case where the spindle was located.
Step 5:
Use a hammer and small phillips screwdriver to pound out the rod in the spindle's middle.
Use a hammer and a larger screwdriver to pound out the ball bearing sleve.
When both are removed the hold that's left is 1/4 inch.
Step 6:
Replace the hard drive platters and spindle.
Step 7:
Insert clock mechanism thru hold from the back and secure with included nut.
Attach the hands and insert a battery.
Step 8:
To make it more to my liking I replaced the second hand with a red one and used the F3, F9, and F12 keys from an old laptop keyboard.
