Hardback E-Reader Case
Intro: Hardback E-Reader Case
How to Turn an Old Hardback Book into a Case for Your E-Reader
What you'll need:
A hardback book that is just a bit bigger than your e-reader, but about the same thickness
Enough fabric to cover your e-reader
About 20" of 1/4 braided elastic
Paperboard, like from a cereal box
Spray adhesive
Hot glue gun
Scissors
Ruler
Utility Knife
STEP 1: Rmoved the Pages From the Book
Using your utility knife, cut the paper in the crease of the binding in the front and the back of the book. Gently pull the pages from the binding. They'll come out in one junk, but you may need to cut through the glue in a few spots.
STEP 2: Cut & Cover the Paperboard
Cut 2 pieces of paperboard to fit the inside front and back covers of the book. Then cut a strip of paperboard about 1/4 inch thinner than the spine of the book.
I'm not huge on measuring so I just laid out my ironed fabric with the paper board pieces on top. Lay one of the big pieces and the spine piece about a 1/8 inch apart. Treat this like on piece from here on out. Place the other one a few inches away. Coat the paperboard, and the fabric an inch or so around it, with spray glue. Remove the cards, spray the fabric beneath them and replace the cards, glue side down. Give the glue a few minutes to dry a bit, then cut the fabric, leaving about an inch around all the edges of the paperboard.
Trim the corners and fold the excess fabric over the edges of the paperboard except the outside edge of the spine piece. You'll want to leave the extra fabric on that edge to make a smooth seam on the finish product (Wait it out - you'll see!).
STEP 3: Attach the Front Inside Cover
Lay the cover of the book out flat, inside up. Coat the back of the front inside cover piece - the one that includes the spine piece - with spray glue and adhere to the book cover. Make sure the spine piece lines up with the spine of the book. Remember that extra inch of fabric we didn't wrap around the back of the paperboard? Lay that flat against the back cover of the book (see photos).
STEP 4: Add Elastic Supports
Cut the elastic into 4 inch pieces. On the back of the remaining fabric covered pieces of paperboard, measure and mark an inch from each corner. Wrap a piece of elastic around each corner. Hot glue the ends of the elastic to the back of the paperboard card at the marks. Try to keep a bit of tension on the elastic when you glue it to the paperboard - you want your Nook to be secure!
STEP 5: Attach the Back Cover
Use hot glue or spray adhesive to attach the paperboard with the elastic to the back cover of the book.
Strap in your e-reader and you're good to go!
27 Comments
AndrewL5 9 years ago
I was inspired by this instructable, if
not entirely convinced that it was the best way to go about making it,
so I instead opted to fabricate from scratch (Somewhat).
I started
with an old keyboard box, the inside membranes from an old USB
keyboard, and an old pair of pants that I'd burned with a hot iron and
wore otherwise destroyed.
I used a spray adhesive to apply the
fabric to the cardboard, and I cut out the decals from the cardboard for
the raised lettering, and logo'd back cover. The bottom corner holders
are some of the old belt-loops from the pants, with small strips of
cardstock threaded into them, and I applied the keyboard circuit
membrane to some black paper, and then onto cardstock for the inside of
the sleeve. There's a similar piece made from the other circuit membrane
under the Nook. I was going to use rivets to hold the loops ion place,
but they don't flatten out enough, so I opted for super-glue.
All
in all, I think it turned out well, and being as this is the 3G version,
I think it only seemed appropriate to do a HHGTTG theme. (I know it's
not a Kindle, but beggars can't be choosers)
probablepossible 8 years ago
this is charming! thank you for sharing!
Amelika 12 years ago
willardx 13 years ago
AliceB777 12 years ago
brassclams 12 years ago
I had an original set of Nancy Drew books as an adolescent. As a young adult I loaned them to an acquaintance, and never got them back.
They helped me through those early-adolescent angst years, so I guess the thought of cutting one up kind of zinged me!
Peace.
sodiumcanine 12 years ago
Neat Idea.
Found it Ironic today, I was at the library and did not pick up one book,
just used my Nook to download E-books and surf the web. Now I plan
to go to a 1$ bookstore ( Springing up everywhere it seems) or a used bookstore to get a book to hack for my Nook.
Hardback copy of Sailing Alone Around The World- Joshua Slocum Hoping
to find. I am reacquainting myself with the Book in Audio form on my MP-3
Tech making DTF (Dead Tree Format) Obsolete?
sleepymyf 12 years ago
I made a couple of minor alterations to mine: instead of using card for inside the front cover, I used a piece of neoprene/craft foam to give a bit of padding; and to keep the book shut, I glued a piece of ribbon onto the inside of the cover before putting the fabric-covered inside pieces in
lsienkiewicz 12 years ago
Goodhart 13 years ago
VERY nice :-)
nancy_sparkz 13 years ago
piccolo1979 13 years ago
Solderguy 13 years ago
MDisdain 13 years ago
Since I couldn't find a decent looking hard-cover book lying around that I could part with, I took this once step further by covering the outside of the book in fabric as well. I used the same method that you outline for the inside, but did the outside first. I can see lots of possibilities here.
B&N cover $29.99-59.99, my cover (made from stuff lying around the house) free.
Thanks!
izzyinsf 13 years ago
Celt 13 years ago
kauaileslie 13 years ago
