Introduction: Have All the Emulators Inside a Portable Joystick
Arcade Portable Joystic
this is my first instructable. please be pantience with me,due to I dont speak english very well.
*The main purpose of this instructable is to take your favorite classic games everywhere inside a usb joystic, In order to run it in any Pc or Laptop,without installing any program.a real s.o linux arcade will be inside the joystic
You will be able to play :
# El objetivo de este instructable es poder llevar con nosotros nuestros juegos clásicos favorito dentro un joystick usb . poder jugarlos en cualquier pc o portátil sin instalar nada y dejando todo tal cual estaba al desconectarlo de pc . podras jugar
( Amiga (500, 1000, 2000, CD32, CDTV), Apple (68k, 128k, 512k, SE, MacOS, Plus), Atari (400, 400 XL, 800, 800XL, 130XE, 5200, Falcon, Lynx, ST, others), Amstrad (CPC, Plus, VEB, others), Arcades (many), Colecovision, Commodore (64, 128, VIC20, PET, others), Doom, GameBoys (GB, GBC, GBA), GameGear, Genesis/MegaDrive, Intellivision, Master System, MS DOS, MSX, MSX2, N64, NDS, NeoGeo, NeoGeo Pocket, NeoGeo CD, NES/Famicom, PC Engine/TurboGrafix, PC-FX, PlayStation, PSP, ScummVM, SNES, Wonderswan, Virtual Boy, ZX Spectrum (16k, 48k, 128k, +2, +2A, +3) and more! )
Step 1: Requeriments
*Hardware Requirements:
Usb Joystick
screwdriver
USB Cable
usb pendrive
drill
silicone coating gun
soldering irons
voltmeter
*Requirements For the Operative System:
A Laptop or Pc
A clean Cd or Dvd
# hardware necesario
joystic usb
destornillador
cable usb
usb pendrive
broca
taladro
pistola de siliconar
elementos para soldar tester
# para instalar el sistema operativo una laptop o pc
un cd o dvd virgen
Step 2: Open the Joystick
*My first goal was to make the minor possible modifications in the
joystick in order to make it an affordable and a cheapest solution, therefore I tried to weld in serial the usb joystick cable with the flash drive trying to achieve something like an USB passive hub but...... unfortunately, the flash drive and joystick were not recognized simultaneously. Therefore, I had two choices: to use an internal hub with a single wire or to use two wires from the joystick, so I chose to use the usb two wires due to the large size of the hub that I could get in my location.
#mi primer objetivo fue lograr hacer las menores modificaciones posibles al joystick y que fuera la solución mas barata, por tanto intente soldar el serie el cable usb del joystick con el de la memoria usb intentando lograr algo así como un hub usb pasivo, infortunadamente el pendrive y joystick no son reconocidos al mismo tiempo.
Por lo tanto: o usaba un hub interno y usaba un solo cable o usaba 2 cables desde el joystick ,me decidí por los 2 cables usb debido al gran tamaño de los hub que puedo conseguir en mi localidad
* unscrew the Joystick and look for the best place to host the usb memory and cable
# desatornille busque el mejor lugar en donde alojar la memoria usb y el cable
* Drill a hole through the joystick with the same diameter as the
USB cable, cut the wire leaving female plug with suitable diameter
# perfore un agujero atraves del joystick del diámetro igual al del cable usb
corte el cable dejando la hembra del diámetro adecuado
Step 3:
* solder again the cut usb cable according to the colors or Check the continuity with a volmeter
# despues de pelar la puntas de ambos lados del cable usb , solde respetando los colores o compruebe la continuidad con un voltimetro
* Hold the cables to the chassis by using hot glue e Put the wires together if you wish
# asegure los cables al chasis usando silicona.junte los cables si lo prefiere
*plug the pendrive to the female usb inside. screw the joystic and plug to pc the cables
# conecte el pendrive a la toma que hemos dejado dentro del joystick . cierre con tornillos . conecte al pc ambos cables el joystick y la memoria
Step 4: System Installation
*System Installation
the key of our Classic Arcade games joystick is the persistent portable Linux installed on the usb flash drive . A pen drive with a live operating system installed on it, has the advantage of turning machines pc or laptop before entering the Windows installed on the hard disk, It runs all sorts of programs (actually a complete operating system) and then leaves in an undetectable manner without touching anything. We installed it in our usb in a persistently way, I mean all the changes that occur during our session will be recorded on the USB memory and remain available for the following sessions.the room we download progress in games and so on. Although there are several ways to install different Linux distributions and highly configurables I have chosen a Linux version called Arcade Puppy due to this version is intended for pre installed games and brings many emulators as well as drivers for the joysticks. Please, Go to page:
http://scottjarvis.com/page105.htm
download the puppy arcade version that suits you
#instalacion del sistema
la clave de nuestro Classic games Arcade portable joystick esta el Linux persistente instalado en el la memoria .
Un pendrive con un sistema operativo live instalado en el, tiene la ventaja de poder encender maquinas pc o laptops antes de entrar en el Windows instalado en el disco duro , ejecutar todo tipo de programas ( en realidad un sistema operativo completo ) y luego salir de forma indetectable sin haber tocado nada .
Nosotros la instalaremos en nuestra usb de forma persistente es decir que los cambios que ocurran durante nuestro sesión se graben en la memoria usb y queden disponibles para las siguientes sesiones .las room que descarguemos los avances en los juegos etc
aunque existen varias formas de instalar y varias distribuciones de Linux muy configurables nosotros hemos elegido una versión de puppy Linux llamada puppy arcade ya que esta destinada para juegos y trae pre instalados muchos emuladores y driver para joystick
vaya a la pagina
y baje la versión de puppy arcade iso que mas le convenga
Step 5: Burn Cd
copie la imagen ISO descargada en un cd o dvd virgen
burn the downloaded iso imagen to the cd
Step 6: In Bios
*This cd is able to boot your machine with arcade puppy instead of Windows.
1. Get ready to act quickly: You need to start the computer and press a key on the keyboard before the BIOS hands over control to Windows. You have only a few seconds to perform this step.
2. Boot (or restart) the PC: Pay close attention to the first screen that appears. Look for a message that indicates which key you need to press in order to access the BIOS. That key is likely to be:
--A Function key (such as F1, F2, or F3)
--The Esc key
--The Delete key
in BIOS choose to boot from the cd or the dvd.
# Este cd es capaz de arrancar su maquina con puppy arcade en lugar de Windows . para hacerlo debe colocarlo en su computadora y cuando este en los primero segundos del encendido, debe ingresar al menú del bios y elegir bootear desde cd or dvd . Para ingresar al bios debe teclear lo que le informe la pantalla de inicio, generalmente:
una tecla de funcion como f2 o f12 o f9 o delete o esc
Step 7: Puppy Universal Installer
*wait for puppy arcade turn on .You will an desktop as in the picture :
now is time to install puppy arcade inside our USB flash drive that is inside the joystick . use the tool called
puppy universal installer
go to: menu --- setup----- puppy universal installer
# espere que puppy arcade encienda . tendra un escritorio similar al de la foto .
como nuestro objetivo es correrlo desde usb pendrive que esta dentro
del joystick ,no desde el cd, utilizaremos la herramienta llamada
puupy universal instaler
vaya a menu --- setup----puppy universal installer
Step 8:
* choose install to a usb stick ( first opcion ).
Choose your usb pendrive .
Choose from CD
Choose “mbr.bin from the syslinux package or default
You may need to set the usb stick’s partition to have a ‘boot’ flag set
using a great tool called gparted. Gparted is quite easy to use, just read what comes up on the purple popup.
# elija install to a usb stick ( primera opcion ).
elija su dispositivo : generalmente linux nombra su pendrive usb como sdb1
Elija cd
elija mbr.bin o default
Es posible que nesesite modificara la particion
Para que sea booteable debe tener un bandera( flag) .si se lo pide revise la particion con gparted que esta en el sistema livedel cd y esta disponible
Step 9:
You may need to set the usb stick’s partition to have a ‘boot’ flag set using a great tool called gparted. Gparted is quite easy to use, just read what comes up on the purple popup.
An orange box should pop up. Press enter to continue.
Congratulations; the stick should now boot Puppy arcade
Elija mbr.bin o default
Es posible que nesesite modificara la particion Para que sea booteable debe tener un bandera( flag) .si se lo pide revise la particion con gparted que esta en el sistema live del cd y esta disponible
en el cuadro narajana presione enter
Listo ya tienes puppy arcade en el pendrive
Step 10: First Boot From Usb Pendrive
*Now shutdown ---reboot ---extract the cd , do not save yet
You can use BIOS boot order or a boot menu to boot off USB pendrive
now in puppy arcade from usb, you can configure zone , time .etc
open the room loader program and configure emulators ,bios, joystics .etc
#Ahora puedes darle menu shutdown -- reboot extraer el cd -- no salves nada aun
al reiniciar cambia el orden de booteo de la bios de cd a el pendrive usb
ahora estaras dandole boot al pc la memoria que esta en el joystick
procede a configurar idioma red etc
abreel programa room loader que se encuentra en el escritorio y configura: emuladores ,bios, joypads etc
Step 11: Save the Session
*now in the first shutdown you can save the session (all you personal data and settings)for the next boot
# en el primer apagado puedes guardar todas tu preferencias archivos , las roms descargadas quedaran en tu pendrive para el siguiente booteo
Step 12: Enjoy
download your favorite romms and enjoy in any pc or laptop .
please vote for me :i want win the yummei ears :
http://yuumei.deviantart.com/gallery/51518646/Axe...
descarga las romm de acuerdo con el emulador y disfruta de tus juegos favoritos en cualquier computador sin instalar nada
por favor vota por mi .quiero ganarme las orejas de yummmei soy gran admirador de todo lo que hace
