Introduction: Have ChatGPT Write a Melody for Arduino Uno
In this instructable, I will produce an example of how easy it is to get ChatGPT to write Arduino code. It is a really simple example of a melody maker for a project that I am making.
- Arduino Uno: https://store.arduino.cc/products/arduino-uno-rev3
- Buzzer: https://www.digikey.ca/en/products/detail/cui-devices/CMT-9648-85T/10326219
- Breadboard: https://www.digikey.ca/en/products/detail/dfrobot/FIT0096/7597069
- Jumper Wires: https://www.digikey.ca/en/products/detail/sparkfun-electronics/PRT-12795/5993860
- Arduino programming cable (Type A to Type B USB): https://www.digikey.ca/en/products/detail/cnc-tech/102-1030-BL-00200/3064828
Those are all the materials I used in this instructable. The links I gave are just suggestions and in fact, the breadboard I showed is not even the one I used. The neat fact is that if you do not have the USB cable you can probably steal one from a printer somewhere because most printers use that cable to connect to computers too.
Step 1: Go to ChatGPT
You might get a response that tells you the servers are busy and you have to wait (like one of the images attached). Hopefully, you get a message like the other image attached and you can just log in.
Step 2: Get ChatGPT to Write the Code
Then simply ask it to write a melody as I did in the image.
Step 3: Copy the Code to the Arduino IDE
Copy ChatGPT's code to the Arduino IDE (as shown in the image).
Step 4: Wire the Uno
Wire the Arduino Uno according to the attached schematic and the two included pictures
Step 5: Upload the Code
Step 6: Listen to the Melody
All that is left is to listen to the beautiful melody! The video attached plays that melody.
