Hawaiian Yarn Lei Tutorial
Intro: Hawaiian Yarn Lei Tutorial
This yarn lei tutorial was originally published on Simply Modern Mom. Please visit Simply Modern Mom for more tutorials and craft ideas.
This is a fun summer luau tutorial, a yarn lei. I decided to tap into my Hawaii childhood and teach you to make a lei with something you can find in non-tropical locations. It’s one of those things that every child learns to do in Hawaii. And if you are thinking of doing a summer luau, this could be a fun activity for the children to do. It will keep their hands busy and out of trouble.
STEP 1: Supplies
yarn
scissors
scissors
STEP 2:
Take the tip from the ball of yarn and have it come from back to palm of your non-dominate hand. Don’t cut the yarn from the ball. You don’t know how much yarn you will need yet.
STEP 3:
Wrap it around you fingers going from the back of your index finger (pointer finger) to the front of your middle finger. Then to the back of your ring finger and front of your pinky. At the pinky, you’ll loop it around to the back of it and wrap the other sides of all your fingers (except the thumb).
STEP 4:
Take the yarn and wrap it around the palm of your hand by going back to front and leave the yarn dangling at the back of your hand placed between the thumb and index finger.
STEP 5:
Lifting the straight line that is at the palm and going under it to pick up the yarn loop that is at the index finger. Pull it up enough to put your index finger through the loop.
STEP 6:
Then do the same thing to the middle, ring and pinky finger.
STEP 7:
Repeat step 4 through step 6 about 10 times. It should start gathering at the back and look like a huge lump. Take the opened end of the yarn and pull on it gently so the gather turn into the lei.
STEP 8:
Repeat step 4 through 7 until you reach the desired length of your lei. Then cut the yarn from the ball of yarn about 5-6 inches out.
STEP 9:
Take the newly cut end and pull it through the index finger loop from bottom up. And repeat to other fingers, always going from bottom up.
STEP 10:
Once you have put the end through all the loops of the fingers, take off from the fingers and pull tightly on the end.
STEP 11:
Tie the two ends together to make the lei. You can add a pom pom or a yarn wheel to where the two ends meet to cover it up better. To make the yarn wheel, you take a card about 4 inches in length. Wrap the yarn around that several times. The more you wrap the fuller the wheel. Then take a piece of yarn and tie the middle in the opposite direction of the rounded up yarn. To make the pom pom, do the same thing as the wheel, just cut the rounded yarn at middle of the loops then fluff. Aloha!
2 Comments
grooooovy 13 years ago
Applejuice11 13 years ago
