Introduction: Headboard With Integrated Bedside Tables and Lighting
I created this custom headboard at the request of a friend who no longer wanted bedside tables or floor cables to facilitate cleaning.
It is made of melamine, equipped with 2 hanging bedside tables with doors and sockets, and an LED lighting system with touch dimmers. It measures 2.5m wide and 1.2m high, it is suitable for a bed 1.6m wide.
Tools used:
- Circular saw
- Plate Joiner
- Router tool
- Miter saw
- Screwdriver
- Drill press
- Hand tools
Cost: 200 €
- 4 melamine panels: 103 €
- 4 Edge Banding: 25 €
- Sheet metal: 11 €
- 2 touch switches: 19 €
- 2 sockets: € 8
- Miscellaneous: 34 €
Time spent: 30H
Materials :
- Melamine boards 2.5 x 0.6 m (18mm thick)
- Edge Banding
- Brushed aluminum plate
- Hinges
- LED strips
- Touch panel switches
- Aluminum holder for LED
- Outlets
- Glue, screws, slats ...
Step 1: Plans and 3d View
I started by drawing a 3D model to realize the final result, from there, I printed the plan.
In total I needed 4 melamine boards of 2.5 x 0.6 meters (thickness 18mm) and to optimize the cuts I drew a cutting plan.
Dimensions are in millimeters.
Step 2: Cut Boards
Following the cutting plans, I used a circular saw with a homemade rail, this rail allows me to cut up to 2.5 m.
To avoid splinters, I first pass the saw upside down to 1mm deep, and I finish by cutting forward over the entire thickness.
For small cuts I used a miter saw.
Step 3: Assembly
For an invisible assembly I used a plate joiner and wood glue.
I dig the 2 parts at the same time with the plate joiner to be perfectly aligned, I insert the strips (also called cookies) and I add wood glue.
The elements are then held in place with clamps while the glue dries.
Step 4:
I stick the edge banding, but since they are a little too wide, I level them with the cutter.
Step 5: Integration of the Brushed Aluminum Plate
To integrate the aluminum strip, I dug 1.5mm into the router by following a ruler on each side, then I finished by hollowing out the center.
I then glued it and it fits perfectly into its location.
Step 6: Door Hinges
Still with an aesthetic concern, I chose invisible hinges.
I dig the doors with a drill bit to clip the hinges, and, on the fixed side, I screw the hinge supports.
Instead of door handles, I chose more discreet pushers: Just press the door to open it.
Step 7: Lamp Holders
I dig the lamp supports with the router (fixed under the workbench) to integrate the LED strips.
I chose an aluminum profile with an opaque cover, it fits perfectly in the housing.
Step 8: Touch Dimmer
I cut a square with the jigsaw, I screw and wire the touch switch / dimmer.
Step 9: Electrical Outlets
I pierce the board with a hole saw to install 2 sockets.
For the 12V supply of the LEDs I got a laptop charger.
Step 10: Up / Down Link
To facilitate transport, I separated the headboard into 4 parts: top / bottom / 2 bedside tables.
To connect the top and bottom I have provided cookies that will only be glued on one side.
Step 11: Wall Fastening System
The headboard will be fixed to the wall on 2 supports.
At the back of the headboard, I make hooks reinforced with an aluminum plate.
Step 12: Pre-assembly
The 2 vertical wall supports also serve to connect the upper part to the lower part.
Step 13: Installation
For the installation I screwed the beveled supports with plasterboard dowels.
The four elements are then transported and assembled on site, and the assembly is fixed to the wall by 2 persons.
Step 14: Done!
It's over ! The bed is put back in place and my friends are very happy with this new creation!
I'm participating in the woodworking contest, don't hesitate to vote for me if you liked it!
