Introduction: Heart Music Reactive Light
Hii Friend,
Today I am going to make a circuit of Heart Music reactive light in which when music will play around this circuit then LEDs will be glowing as music.
Let's get started,
Step 1: Take All Components As Shown Below
Components required -
(1.) Transistor - NPN (2N222) x1
(2.) LED - 3V (Any color) x{As LEDs required to make heart.It will depend upon the size of the heart}
(3.) Mic x1
(4.) Resistor - 33K x1
(5.) Battery - 9V x1
(6.) Battery clipper
Step 2: Make Heart of LEDs
Firstly we have to make Heart of LEDs as you can see in the picture.
NOTE : Legs of LEDs connect in Parallel (Connection will be +ve of all LEDs to each other and -ve of all legs of LEDs to each other).
~Use Cardboard to make this Heart of LEDs.
Step 3: Connect Transistor - 2N222
Next we have to connect transistor to the Heart of LEDs.
Solder Collector pin of Transistor to -ve pin of LEDs as you can see in the picture.
Step 4: Connect 33K Resistor
Next we have to connect 33K resistor to the circuit.
Solder 33K Resistor between base pin of transistor to the +ve legs of LEDs as solder in the picture.
Step 5: Connect MIC
Next Connect the wires of MIC.
Solder +ve wire of mic to the Base pin of transistor and
solder -ve wire of Mic to emmiter pin of the transistor as you can see in the picture.
Step 6: Connect Battery Clipper Wire
Next we have to connect battery clipper wire to the circuit.
Solder +ve wire of battery clipper to +ve legs of LEDs and
Solder -ve wire of battery clipper to Emmiter pin of the transistor as solder in the picture.
Step 7: How to Use
This Heart music reactive light circuit is ready.
To use this circuit connect 4V Battery to the Circuit and say somethig/play music.
As music will give sound like that LEDs will glow.
NOTE : We can give Input Power supply (4-6)V DC.Here I used 9V Battery for demonstration purpose.Please you don't use 9V Because transistor can be damage.
Thank you
