Introduction: Heart Reactor (Anahat Chakra)
Jai Hind all of You !
This is basically a Heart Reactor placed on our Anahat Chakra. I was wondering from ECG sensor then i though i should make a creative thing with it, and it must be werable. Althoug it is inspired by Arc Reactor obviously but i have change a little bit convept !
It reacts according to your Heart Rate using AD8232 ECG sensor and i have created a small Heart in that light travels according to RA, LA, RV, LV... Yes according to your PQRSTUV waves.
So lets Starts !
You will need below materials !
1 AD8232 ECG Heart Rate Sensor
1 PCB for Hear Circuit Wires Ardiuno Lithium Battery 5 to 9 Volt Box for Ardiuno
1 Circular Box 2 One way Mirrors 1 Glass Cutter Black Tape
Red and Yellow Leds 10 to 15 apx 1 k resistance for Leds
1 Black Belt (3 Mtr)
Soldering Machine Glue Gun + Glue Sticks Forcep Fabric or Water Color
Printed Anhat Chakra (Image Given)
and Other tools you may use to improve or as required !
Step 1: Step 1: Creating Heart Circuit
Take a white paper and draw 3 x4 cm Heart shape roughly to cut PCB.
Then mark on PCB and cut it as per shape.
Take 4 Leds for RA, LA, RV and LV !
Arrange and connect all 3 Leds and 1 Yellow Leds as givne in the images
Step 2: Step 2 : Creating the Circular Circuit
To make more creative we have to make a circular circuit you may use your creativity !
To do this take a Hard paper strip around 1.5 cm and arrange and connect 3-4 red and yellow leds with resistance as required.
Step 3: Step 3 : Wiring, Connections and Coding
Then Connect all the wiring as given into the Code !
Step 4: Step 4 : Glass Cutting According to Circular Box
Take a circular box with apx 9 cm width and 4 cm height to arrange all the thing in it.
Take two one way mirrors and cut a circular shape according to the box.
Be catious when working with glass !!!
Step 5: Step 5 : Making It Wearable
Take a black belt around 3 meter and arrange and connect as given !
Step 6: Step 6 : Creating a Small Heart Model
Create a heart as given step by step using Glue stick ! Explore your creativity .
Step 7: Step 7 : Arranging All in the Circular Box and Testing !
Arrangne all the thing in the Box as given !
Step 8: Step 8 : Preparing the Cap of the Circular Box
Cut the cap and attach the mirror in the cap .
Step 9: Step 9 : Taping and Decoration
Hereuse your creativity i used black tape and a Anahat Chakra Image to decorate it !
and Test it !!
Step 10: Step 10 : ECG Sensor Connections (Wearing It Properly)
Connect ECG sensor
Red one for Right Chest
Yellow one for Left Chest
and
Green one below right stomach !
and and Power the Ardiuno and Voila !!!!
Play with Heart Reactor !!!
