Heat Shrink USB Mod
Intro: Heat Shrink USB Mod
Got some extra heat shrink tubing? Here is a quick and easy case mod for a USB stick! Yes, this is another USB case mod... But don't get upset, this one has never been done before! It's fairly straight forward to do, and pretty cool.
STEP 1: Supplies
You will need the following for this project:
Tools:
- Scissors - $2.00
- Lighter - $2.00
- Large Heat Shrink Tubing (any color, I chose yellow) - $2.00
- USB Stick - $20.00
STEP 2: Remove the Previous USB Case
I don't have pictures for this step, so stick with me!
Different USB cases come off in different ways. With some you have to slide a thin piece of metal into the side, then pull the two pieces apart. With others you have to pry it open with a knife. So find a way that works for you. You can be as brutal as you want, because I will not be using the case for this project.
STEP 3: Slide, Cut, Heat, Cut.
Now for the "Slide, Cut, Heat, Cut." stage.
1.SlideSlide the large heat shrink tubing over the USB stick's components.
2.CutCut the heat shrink tube about a half an inch from the back of the USB stick.
3.HeatHeat up the shrink tubing with a lighter, the same way you normaly would with wires.
4.CutCut the excess shrink tubing from the end. You should leave a few millimeters.
STEP 4: Repeat (optional)
If you want, you can repeat step 3 as many times as you wish. I repeated it once, but put the tubing a little further back. See image.
STEP 5: Done!
So there you go! A heat shrink USB mod!
Remember to rate and comment!
P.S.
Do you like my awesome image?
P.S.
26 Comments
szdicore 9 years ago
we are Dicore heat shrink tubing supplier, could supply this heat shrink for USB mod, just visit us at www.dicoretubing.com
eccentricafterglow 10 years ago
GASSYPOOTS 12 years ago
pcfan 12 years ago
tbh-1138 12 years ago
shadow wave rider 12 years ago
Furball_Fidelis 12 years ago
Valeil 13 years ago
tobyscool 12 years ago
WKD_Side 13 years ago
Jodex 14 years ago
Hakimi 14 years ago
chris.t.r 14 years ago
B.F.L.M 14 years ago
Arbitror 14 years ago
liteoner 14 years ago
killroywasnothere 14 years ago
ironsmiter 14 years ago
