Introduction: Heavy Bass Controller Circuit
Hii friend,
In music system we want high bass sound.If in your music system bass is very low then this blog will be very helpful for you.Today I am going to make a Heavy bass circuit.You can make easily this circuit.This circuit doesn't take lot of components.
It's circuit require only 4-components and 1-potentiometer.This circuit will give heavy bass with very good quality sound.
Let's get started,
Step 1: Take All Components With Potentiometer As Shown Below
Components required -
(1.) Potentiometer - 100K x1
(2.) Resistor - 10K x2
(3.) Resistor 1K x1
(4.) Ceramic capacitor - 0.01 uf/103pf
(5.) Ceramic capacitor - 0.001 uf/104pf
Step 2: Solder 0.001 Uf Capacitor
Solder 0.001 uf in 3rd pin and middle pin of the potentiometer as shown in picture.
2nd pin of potentiometer is audio output and 3rd pin is GND (Ground).
Step 3: Next Solder 0.01 Uf Capacitor
Next solder 0.01 uf ceramic capacitor to 1st pin and 2nd pin of the potentiometer as picture.
1st pin of potentiometer is audio Input and 2nd pin is audio output.
Step 4: Now Solder 10K Resistor
Now solder 10K resistor to 1st pin of the potentiometer as picture.
Step 5: Next Solder 1K Resistor
Next we have to solder 1K resistor to the circuit.
Solder 1K resistor to 3rd pin of the potentiometer as solder in the picture.
Step 6: Again Solder 10K Resistor
Again solder 10K resistor in middle pin of the potentiometer as shown in the above picture.
This picture shows location of all components.
Step 7: This Picture Shows the Connections of Amplifier
This picture shows the connections of amplifier.
As IN (aux audio) shows the Input signal of aux cable, IN(amplifier) shows we have to give input on the amplifier and GND shows ground of the circuit.
Step 8: Circuit Is Completed
Now heavy bass circuit is completed.
This circuit we have to connect in the amplifier to increase bass.
This type we can make heavy bass controller circuit easily at home.
Thank you
