Heliostat Reflects Sunlight Inside
Intro: Heliostat Reflects Sunlight Inside
I like sunshine, and can't get enough of it. So I wanted to build my own heliostat to track the sun and reflect the light into a room. I have searched for projects on the Internet, but most of them are just sun trackers for solar panels, have a tiny mirror, are just experimental to demonstrate the idea or for some other use case. So the only solution would be to design my own.
I have a Lamp with a dichromatic film inside and reflective metal mesh around. I bought it after I have seen this Instructable: https://www.instructables.com/Dichroic-Lamp-LEDs-But-No-RGBs/ When the sunlight hits the lamp, it creates colorful reflections in the whole room as shown in the picture above.
My first prototype was build of wood and uses servo motors to move the mirror. The servos are controlled by an Arduino and a realtime clock.
I was really happy with the result, but it was not very accurate and fails after a rainfall since the wood bends and the mechanic sometimes fails until it is dry again. There where other issues as well, so I decided to build a new one with parts from my new 3D printer.
This Instructable skips version 1 and shows how this new heliostat is build and what was done differently to hopefully work better.
STEP 1: Design Considerations
As said in the introduction, I had already a prototype running for a year. Since you can learn a lot from a prototype, here is what I learned:
- Wood is not good for mechanical parts outside
- Electronics does not like humid air
- It is hard for the software to compensate poor mechanics
- Controls and signal lights on the device don't survive the weather for too long
- Cheap plastic mirrors may deform which is a problem for a heliostat
- A 'real time clock' module is not accurate enough.
- This is really a cool project, I want to build an improved version.
Therefore the requirements for the new version are as follows:
- A weather proof design which does not deteriorate in a humid environment and has a dry place for the electronics
- High mechanical precision
- Automatic calibration
- Monitoring and control from the inside
- Use of glass Mirrors
- Should also work in winter
- Over the air software updates
I will show in later steps how I improved the design. The main requirement is of course that it should work reliable with minimal maintenance.
STEP 2: 3D Printed Parts
All parts except of the electronics, the steppers, the screws and the mirrors are 3D printed.
I am quite new to 3D printing and designing this device was quite a challenge. To be sure that everything works, I have created some prototype parts. I wanted to test the following:
- Do the parts fit together correctly? Especially since the size of the mirror is much bigger than the printing area of my 3D printer I have to make them connectable after printing.
- Do the bearings fit together nicely? Do I need a ball-bearing?
- How do the gears fit together? Does it work when moved via the stepper motors?
The result is working nicely, is light, does not use up too much filament and holds enough space for the electronics.
You can find the STL files in this Git Repository. The parts fit for a mirror with 30x30cm (a little less than 12x12 Inch). Since I have bought my mirrors from IKEA in Europe they are of course metric.
There are no specific print settings, I have increased the infill a bit to make it more sturdy, but it should also work with the default infill. You should use white or another color which does not heat up in the sun, since the heliostat need to stand in direct sunlight and dark parts could melt.
STEP 3: Electronics
One of the challenges for the electronics is the power supply. While the stepper motors work best with high voltages from 12-30 volts, the microcontroller needs 3.3 or 5Volts. The best way to power the microcontroller is via an USB cable.
The stepper motors can either be supplied via a separate power supply with higher voltage, or a step-up module from USB to at least 12 Volts, better 15-30. Higher voltage increases the torque of the motors and reduces the probability of lost steps. This is not so critical, since no high motor speeds are needed. It is also possible to use a step down module from the stepper motor voltage to the processor voltage.
The circuit plan does not show the power supply possibilities, it just shows which pins need high voltage, and which low. The ground pins can be connected, but you don't need to do this manually, the motor driver takes care of this.
The bush buttons are triggered when the endstops of the rotation is reached and are used for the calibration of the device. Be sure you connect them correctly, otherwise the software does not recognize them accordingly and calibration fails.
STEP 4: Moving Parts
The mirror is placed on a holder which can tilt the mirror which is sitting on a big cogwheel to turn the mechanism.
Both axes, elevation to tilt the mirror and azimuth to rotate the mirror vertically are driven by stepper motors. Since I wanted to have a high accuracy and more robustness against wind, I printed a 10:1 gear from motor to mirror this increases the theoretical stepper motor limit from 1.8 degrees (200 steps per rotation) by 10 times. Theoretical because the stepper motor drivers have also micro steps to increase this accuracy up to 16 fold. This works only when you power the stepper motors continuously. Since I wanted to power the heliostat with solar power, I need to shut them down in between, otherwise too much power is consumed. This is no problem, but you cannot use micro steps since repowering the motor could lead to inaccuracies. So in fact it is a problem, since also the driver looses its position and you have to start again from a zero position which is not only loosing micro steps but also the coil polarities. So the accuracy is only 1/4 of one step of 1.8 degrees = 7.2 degrees. I have programmed the software accordingly and don't care too much since I still have less than one degree with the 10:1 gear.
Overall the mechanical accuracy of the 3D printed parts is not too high, but still high enough to not influence the result.
STEP 5: Software
I thought about writing the software on my own in C++ as I did for the first wooden prototype, but I wanted to try something new and also needed more functionality. Therefore I use ESPHome for the software. This enables me to easily add further capabilities:
- Monitor and control from the inside (via Website on Wifi)
- Over the air updates
- Clearer design of the software (ok, this is not a feature)
This is requires an ESP32 since a standard Arduino does not have WiFi.
ESPHome is a tool which compiles a firmware by using a one or more YAML files. This makes it very easy to create your own firmware. Some C++ programming was still needed for the mirror calculation and some calibration parts, but this can be directly added to the YAML files.
What does the Software do?When the software is powered up, it connects to the WiFi via the entered credentials in file secrets.yaml. You need to create your own since it is not part of the Git repository:
wifi_ssid: "Ssid"
wifi_password: "password"
mqtt_broker: "127.0.0.0"
Enter your SSID (Wifi name) and password accordingly and enter the IP address of your MQTT broker. When you have no MQTT broker running, you don't need this, the logs can also be seen on the webpage.
The device then provides a webserver at the address heliostat.local which can be opened with a web browser.
The webpage shows the log and has some controls for calibration.
The current time is automatically received from the internet. See the admin.yaml files for details. The timezone is UTC since the sun does not care about local timezones. All you need to do is to set the Latitude and Longitude coordinates in the substitutions section of the heliostat.yaml file. You can use google maps, mark a point, and the coordinates are shown in the bottom of the screen.
CalculationThe calculation is triggered by a timer every 30 seconds. The new mirror position is calculated and updated.
RepositoryThe Coding is in this Git Repository.
STEP 6: Setup and Calibration
Calibration of the mechanics is automatic. To find the correct position for the device make sure it is placed on a even surface. Then click on the turn into sun switch at the web interface. The mirror should now face directly into the sun. Use the crosshair at the top to check this and move it accordingly when it does not fit. Deactivate the switch again. Now setup the target. There is a slider to set the target angle. Adjust it to reflect the sun on your target. The heliostat will correct the mirror position within a few seconds. The mirror should now always reflect the sun to the target. Although the mechanics supports a wide area, be sure your target is somewhere in the south to get the maximum amount of light. Targets which are lower than the heliostat are not possible except when the suns elevation is really high.
STEP 7: Result and Next Steps
That's all. This device is fun in summer and in winter. And will hopefully survive longer than my wood version.
Watch the video if you haven't already watched it. It is the same as in the introduction.
Maybe there will be a version 3. I still have some ideas how to improve:
Power saving, shutdown over night
Auto calibration by searching the sun
Pause when light conditions are not good
OTA only on demand via MQTT
Data logging
Most of them could be added to the software, so no new build is needed.
A smaller and even easier to build version would also be an idea. But there are still other projects to finish...
I hope you enjoyed this Instructable. I case of questions, just leave a comment.
8 Comments
hosseinghasedii 7 weeks ago
high? like how many degrees?
Greetings,
Due to certain physical constraints within my residence, I am required to mount the heliostat on a pole at a level above the ceiling. Could you please advise if there is a possibility to modify your design to accommodate this limitation? If so, could you provide guidance on how this could be achieved?
Thank you.
MartinMemol 4 weeks ago
Hello hosseinghasedii,
Basically the minimum elevation angle of the mirror is about 8 degrees. Therefore the target can be the current sun's angle -(8*2) degrees below the heliostat. This may be ok at noon when the sun is high above, but limits the target in the morning and evening.
After moving my heliostat to a different location, I have the same issue. Therefore I thought it should be possible to tilt the whole device towards the target and tell the software to correct the mirror direction accordingly. I am currently testing this with an inclination of 13 degrees, but currently missing some accuracy. Furthermore the effect will be less effective for sun angles further away from the target. But I think it is a good idea and will definetly help.
Another solution would be a different 3D print design. I haven't thought about this yet. Since the 3D design files are also in the repository you can try this on your own.
OlliP1984 2 months ago
Tolles Projekt. Die Lampe hat mich schon abgeholt bzw. meine 8 Jährige Tochter. Sie möchte das auch. Zumal Ihr Zimmer Richtung Norden ausgerichtet ist und dadurch etwas reflektierte Beleuchtung gebrauchen könnte. Danke für die Anleitung. Ich werde mich einmal daran versuchen.
MichaelP453 7 months ago
milanchen 7 months ago
Thank you for that.
BurtG 7 months ago
MartinMemol 7 months ago
This is the IKEA KARISMATISK lamp. Unfortunately it was a limited edition, so it is no longer available. I bought it some years ago after I have seen this Instructable:
https://www.instructables.com/Dichroic-Lamp-LEDs-B...
jessyratfink 8 months ago
