Introduction: Help With My Arduino Project. (2, 7 Segment With Piezo Buzzer and Relay)
Hi, i need some help with my arduino project.
I have 2, 7 segment displays which countdown from 20 to zero en then the piezo buzzer beebs for a while.
My question is:
I want a relay switched on for 20 second at the same time with the 7 segment countdown.
so if the countdown starts, the relay opens and when it is complete 20, 19, 18, 17, 16,15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0 then the relay should close.
here is my code for so far.
if anyone can help me with tips or anything, that would be awesome ;)
gr Mark
int pin1 = 2;
int pin2 = 3; // --6--
int pin3 = 4; // 5 | | 7
int pin4 = 5; // |--4--|
int pin5 = 6; // 1 | | 3
int pin6 = 7; // --2--
int pin7 = 8;
int gnd1 = 11; // gnd1 is display 1's gnd
int gnd2 = 9; // gnd2 is display 2's gnd
int timer = 100; // A timer, to run the for loop 500 times, which turns out as 1 second.
int value; // The value, part of the FADING display
void setup(){
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT); //The following sets up all of the pins for use.
pinMode(pin5, OUTPUT);
pinMode(pin6, OUTPUT);
pinMode(pin7, OUTPUT);
pinMode(gnd1, OUTPUT);
pinMode(gnd2, OUTPUT);
pinMode(12, OUTPUT); // Output for the repeating beep
for (int i=0; i digitalWrite(pin1, B0);
digitalWrite(pin2, B0);
digitalWrite(pin3, B1);
digitalWrite(pin4, B0);
digitalWrite(pin5, B1);
digitalWrite(pin6, B0);
digitalWrite(pin7, B0);
digitalWrite(gnd1, B1);
digitalWrite(gnd2, B0);
delay(5); // Writes 20 to the display.
digitalWrite(pin3, B0);
digitalWrite(pin4, B1);
digitalWrite(pin5, B0);
digitalWrite(gnd1, B0);
digitalWrite(gnd2, B1);
delay(5);
for (int i=0; i digitalWrite(pin1, B1);
digitalWrite(pin2, B1);
digitalWrite(pin6, B1);
delay(5); // Writes 19 to the display.
delay(5);
delay(5); // Writes 18 to the display.
delay(5);
delay(5); // Writes 17 to the display.
delay(5);
delay(5); // Writes 16 to the display.
digitalWrite(pin7, B1);
delay(5);
delay(5); // Writes 15 to the display.
delay(5);
delay(5); // Writes 14 to the display.
delay(5);
delay(5); // Writes 13 to the display.
delay(5);
delay(5); // Writes 12 to the display.
delay(5);
delay(5); // Writes 11 to the display.
delay(5);
delay(5); // Writes 10 to the display.
delay(5);
delay(5); // Writes 09 to the display.
delay(5);
delay(5); // Writes 08 to the display.
delay(5);
delay(5); // Writes 07 to the display.
delay(5);
delay(5); // Writes 06 to the display.
delay(5);
delay(5); // Writes 05 to the display.
delay(5);
delay(5); // Writes 04 to the display.
delay(5);
delay(5); // Writes 03 to the display.
delay(5);
delay(5); // Writes 02 to the display.
delay(5);
delay(5); // Writes 01 to the display.
delay(5);
delay(5); // Writes 00 to the display.
delay(5);
void loop() {
digitalWrite(12, HIGH); // set the beep on
delay(300); // wait for amount of time
digitalWrite(12, LOW); // set the beep off
delay(500);
digitalWrite(13, HIGH); // Turns the TIMER ENDED LED on.
for(value = 0 ; value <= 255; value+=5) // fade in (from min to max)
analogWrite(gnd1, value); // sets the value (range from 0 to 255)
analogWrite(gnd2, value); // sets the value (range from 0 to 255)
delay(10); // waits for 30 milli seconds to see the dimming effect
for(value = 255; value >=0; value-=5) // fade out (from max to min)
delay(10);
My question is:
gr Mark
int pin1 = 2;
int pin7 = 8;
void setup(){
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
for (int i=0; i
delay(5);
void loop() {
delay(500);
delay(10);
